93 tune
duster360
Re: RE: Re: RE: Re: RE: 93 tune
Post by duster360 »
newsrt4 wrote:so i went back to stock flash at WOt i will get anywhere between 10.8-11.00.
as far as the knock before i messed with it i was getting about 4-6.00 counts of knock between 3500-6000 rpm then pretty much went away once i retarded about 3.00 degrees.
i dont have the usd wire i just ordered and hasn't come in yet. so i wont be able to load up the data.
the wideband sensor is before cat.
im on stock fuel system and never changed out my fuel filter and have about 90,000 on my all fuel system
Stock tune sounds a little leaner than normal, everything else you've said sounds fine.
The "fuel filter" is made into the pressure regualtor and they're about $120. A simple fuel pressure test at WOT would varify whether or not there's an issue with the fuel system suppling enough volume.
newsrt4
RE: Re: RE: Re: RE: Re: RE: 93 tune
Post by newsrt4 »
how much fuel pressure should i have at wot and does the dsp log fuel pressure or do i need to hook up a gauge
duster360
Re: RE: Re: RE: Re: RE: Re: RE: 93 tune
Post by duster360 »
newsrt4 wrote:how much fuel pressure should i have at wot and does the dsp log fuel pressure or do i need to hook up a gauge
Fuel pressure should be the same as it is at idle--58psi +/-5psi.
No the PCM doesn't monitor fuel pressure. If it did, it would adjust for it. Attach a pressure gauge to the rail and I tape mine to the windshield temporarily.
newsrt4
RE: Re: RE: Re: RE: Re: RE: Re: RE: 93 tune
Post by newsrt4 »
okay
thanks for ur help
Quick
Post by Quick »
duster360 wrote:Attach a pressure gauge to the rail and I tape mine to the windshield temporarily.
That's what he tells everybody... he's had all his gauges taped to the windshield for more than a year now. ghetto gauges. :lol: :lol: :lol:
just kidding
2006 Magnum SRT8
AFE Stage II
Mopar Cat Back
185* T-stat
RDP tune by Steve
duster360
Post by duster360 »
yeah its getting hard to see out the windshield
