Ok great, thank you for letting me know on that oneMike_Levy wrote:The lag off idle is pretty much gone. Theres a slight surge thats happening randomly now. Not able to pinpoint exactly the circumstances (its randomjohan wrote:Let us know on the lag feel also.), so its gonna have to stay.
2009+ Cadillac CTS-V
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Thanks for supporting the CTS-V. I am considering buying a Trinity. I currently have a CAI installed, and have a 2.55 upper pulley waiting to be installed. Will the 91 octane tune be safe for this application? Also, the car is an automatic. I understand it will tune the TCM as well. Does it leave enough TM in the transmission to be safe? Thanks.
yes, yes, and yesTexasCTSV wrote:Thanks for supporting the CTS-V. I am considering buying a Trinity. I currently have a CAI installed, and have a 2.55 upper pulley waiting to be installed. Will the 91 octane tune be safe for this application? Also, the car is an automatic. I understand it will tune the TCM as well. Does it leave enough TM in the transmission to be safe? Thanks.
The 91 tune will work great with your current set up, then swap to the pulley tune once you up the boost.
TM is not removed, just reduced
mikel wrote:yes, yes, and yesTexasCTSV wrote:Thanks for supporting the CTS-V. I am considering buying a Trinity. I currently have a CAI installed, and have a 2.55 upper pulley waiting to be installed. Will the 91 octane tune be safe for this application? Also, the car is an automatic. I understand it will tune the TCM as well. Does it leave enough TM in the transmission to be safe? Thanks.
Terrific Mike. Thanks. Just ordered one. How robust is the data logging feature? And is the Trinity set-up to recognize knock retard in case I need to tone things down? I imagine the initial tune is pretty conservative. I live in a hot climate, well above sea level and have 91 octane to boot.
You can see anything you need.
There is a knock pid, and you can see actual timing, commanded timing, commanded AFR, boost, inj pw, and more
The tunes are conservative for sure.
Spoke too soon. When the car is cold the lag is still there, and it bangs into gear. 43°. Lagged, then it short shifted into 2nd HARD.johan wrote:Ok great, thank you for letting me know on that oneMike_Levy wrote:The lag off idle is pretty much gone. Theres a slight surge thats happening randomly now. Not able to pinpoint exactly the circumstances (its randomjohan wrote:Let us know on the lag feel also.), so its gonna have to stay.
See if you can get a log of that...its gonna be a while before we see 43*
Your injector has completely maxed out and only ran 100%, you just ran it past its operating range... It is impossible to physically run an injector HIGHER than 100%.
so yeah, if your duty cycle is reading 110%, you need bigger injectors man... generally, you don't want the duty cycle to be more than 80-85%....
