Page 8 of 10
Posted: Fri Nov 18, 2011 9:11 am
by johan
Mike_Levy wrote:johan wrote:Let us know on the lag feel also.
The lag off idle is pretty much gone. Theres a slight surge thats happening randomly now. Not able to pinpoint exactly the circumstances (its random
), so its gonna have to stay.
Ok great, thank you for letting me know on that one
Posted: Fri Nov 18, 2011 4:42 pm
by TexasCTSV
Thanks for supporting the CTS-V. I am considering buying a Trinity. I currently have a CAI installed, and have a 2.55 upper pulley waiting to be installed. Will the 91 octane tune be safe for this application? Also, the car is an automatic. I understand it will tune the TCM as well. Does it leave enough TM in the transmission to be safe? Thanks.
Posted: Fri Nov 18, 2011 4:48 pm
TexasCTSV wrote:Thanks for supporting the CTS-V. I am considering buying a Trinity. I currently have a CAI installed, and have a 2.55 upper pulley waiting to be installed. Will the 91 octane tune be safe for this application? Also, the car is an automatic. I understand it will tune the TCM as well. Does it leave enough TM in the transmission to be safe? Thanks.
yes, yes, and yes
The 91 tune will work great with your current set up, then swap to the pulley tune once you up the boost.
TM is not removed, just reduced
Posted: Fri Nov 18, 2011 5:50 pm
by Mike_Levy
Mike, Are you gonna fix the dashboard or should I mess with it myself?
Posted: Fri Nov 18, 2011 6:07 pm
by TexasCTSV
mikel wrote:TexasCTSV wrote:Thanks for supporting the CTS-V. I am considering buying a Trinity. I currently have a CAI installed, and have a 2.55 upper pulley waiting to be installed. Will the 91 octane tune be safe for this application? Also, the car is an automatic. I understand it will tune the TCM as well. Does it leave enough TM in the transmission to be safe? Thanks.
yes, yes, and yes
Terrific Mike. Thanks. Just ordered one. How robust is the data logging feature? And is the Trinity set-up to recognize knock retard in case I need to tone things down? I imagine the initial tune is pretty conservative. I live in a hot climate, well above sea level and have 91 octane to boot.
Posted: Fri Nov 18, 2011 6:31 pm
You can see anything you need.
There is a knock pid, and you can see actual timing, commanded timing, commanded AFR, boost, inj pw, and more
The tunes are conservative for sure.
Posted: Fri Nov 18, 2011 6:33 pm
by TexasCTSV
Terrific. I look forward to learning the unit.
Posted: Fri Nov 18, 2011 7:15 pm
by Mike_Levy
johan wrote:Mike_Levy wrote:johan wrote:Let us know on the lag feel also.
Spoke too soon. When the car is cold the lag is still there, and it bangs into gear. 43°. Lagged, then it short shifted into 2nd HARD.
Posted: Sat Nov 19, 2011 4:04 pm
See if you can get a log of that...its gonna be a while before we see 43*
Posted: Tue Nov 22, 2011 12:22 pm
by Mike_Levy
It hasn't been getting that cold here either. Next time it does I'll get the log.
Posted: Thu Dec 22, 2011 4:45 am
by 08siturbo
Hey I was just wondering if the stock injectors could handle 15psi. I am about to put on a 9.1 lower pully to run with my 2.5 upper pulley. So im going to be right at 15psi. I have 80# injectors on hand to put in, but if I do can someone make a base tune for me so I can dial it in myself?
Posted: Thu Dec 22, 2011 11:43 am
by Mike_Levy
Put it on and then log the IPW to see if they're maxxing out.
You have a bigger heat exchanger, right? Otherwise thats too much boost and you'll heatsoak, get knock and lose power.
Posted: Thu Dec 22, 2011 1:38 pm
by 08siturbo
Ok I have not logged ipw but my idc was at 110% at only 12.75 psi. Which leads me to belive the stockers could not handle another 2 psi.
Posted: Thu Dec 22, 2011 2:02 pm
by 06MonteSS
Your injector has completely maxed out and only ran 100%, you just ran it past its operating range... It is impossible to physically run an injector HIGHER than 100%.
so yeah, if your duty cycle is reading 110%, you need bigger injectors man... generally, you don't want the duty cycle to be more than 80-85%....
Posted: Thu Dec 22, 2011 2:33 pm
by 08siturbo
Ok thats what I was thinking. I will go ahead and put these in next week. Would it be posible to get the pulley tune scaled back for my 80# injectors. Is it something I could do or would have to get done. There is really not a good gm cmr tuner close to me.
