Page 8 of 33
Re: Latest Intune release here.
Posted: Sat Apr 27, 2013 4:16 am
by denali619
hi
i have denali 2010 and i got intune, but am wondering what is the best tune to select, and how to unlock the speed limit ?
i don't know how to use it, can someone help me ?
Posted: Sat Apr 27, 2013 2:37 pm
inTune user manual: http://diablosport.com/manualFiles/inTu ... Manual.pdf
if you use 87/89 octane gas in the truck, then install the 87 Octane Tune...
if you use 91 octane or higher gas in the truck, then install the Diablo Tune...
you can modify the tune to disable the speed limiter...
Posted: Wed May 01, 2013 3:59 pm
by mhelmer
Hi there.
I tried to use my new tuner on my 2012 Ram 1500 5.7L and I got to the screen where it says "you may need an update" and could get no further. It asked to connect the DCX to a PC (I have an iMac). I see from this thread that we must register the product to unlock it? I have attached my INFO.XML file. I have also looked at the Firmware info, already in the tuner:
Application: 1r03h
DCX Tune Db: 1r01b(ok)
DCX PID Db: 1r01a(ok)
FORD PID Db: 1r01a(ok)
GM PID Db: 1r01a(ok)
DTC PID Db: 1r01a(ok)
VIN Db: 1r01c(ok)
Info Db: 1r01b(ok)
Are these the latest, or do I need updated files to drag and drop into the tuner?
Thanks!
Mat.
I-1000-DCX data
Posted: Thu May 02, 2013 11:21 pm
by Wolflead6
Where can I get info on what is in each of these tunes (Diablosport & 91 Octane) in my I-1000-DCX for my 2012 JGC 5.7L Hemi? Would like to know the difference other than the Octane.
Posted: Fri May 03, 2013 9:06 am
mhelmer wrote:Hi there.
Application: 1r03h
VIN Db: 1r01c(ok)
Info Db: 1r01b(ok)
Thanks!
Mat.
Here is the cal update, drag/drop it to the intune drive and let the tool import it, then go to the truck and load the update, then you may load the tunes.
Re: Please help me with registration
Posted: Sat May 04, 2013 7:19 am
by AlexIV
I can't do it via normal procedure. I'd tried many times in paralles Win 8 on my MAC an even using pc
Please send me the registration file and the latest updates (JGC 5.7 Hemi Euro version)
Thanks a lot in advance
Posted: Fri May 10, 2013 11:09 am
by fightingirish67
Is there one that will allow me to register my I-1000-DCX for my 2013 Dodge Charger R/T 5.7L. In the registration field it only goes to 2012 for Dodges and only Ford,GMC,Cadi's, for the 2013 year models. Any idea to allow me to register my unit, I know the tuning for the 2013 Dodge isn't done yet, but I would like to register it.
Posted: Mon May 13, 2013 2:14 pm
by ltwhite
Despite getting all of the PC updates today after unboxing, I'm having the same problem as the other 2011 and 2012 Dodge Charger guys with 3.6L are having with the DCX.
On the vehicle, it recognizes the VIN but you get the message "Vehicle may need calibration update." If you choose the red X, then you get the message "Vehicle unsupported - contact Diablosport."
If you try it again and instead choose the green check, it says "Disconnect from vehicle and connect to PC to check for updates."
However, when I connect to PC and run the Intune Updater, it says "Checking internet for calibration updates" along the bottom and then I get a pop up message that says "Contact Diablosport 68060761AG."
I was so stoked when it was delivered today but my smile is turning into a frown..
Posted: Mon May 13, 2013 3:18 pm
AlexIV wrote:I can't do it via normal procedure. I'd tried many times in paralles Win 8 on my MAC an even using pc
export SUV models are not supported, we have no way to add support for them.
Posted: Mon May 13, 2013 8:18 pm
by engscott78
Mac guy trying to register a second hand Intune.
I've got a '13 Silverado 5.3L gas but would like it all the way updated.
This forum is a bit confusing, it's not possible to tell which is the most current update. Can you guys update only one post as opposed to people having to search through several pages?
Would you please provide the necessary downloads to register and update this thing?
Also, the info.xml file I attached was a copy, does it need to be the only one and it's replaced with the update, or is a copy ok?
Thank you very much.
Posted: Tue May 14, 2013 10:19 am
engscott78 wrote:Mac guy trying to register a second hand Intune.
drag/drop this file to the intune drive to register the device.
all the files to update are in this thread...
Posted: Tue May 14, 2013 2:25 pm
by engscott78
Thank you for the registration.
If I drag and drop each update listed in this thread, I'll be good?
For instance, page one has VIN-1r01c and page three has Vin-1r01b.
Is the most recent alphabetic character the most recent update, or is the most recent update posted later in the thread?
Understand my confusion since I'm not titling the updates I don't know which is most current and am not sure the consequence if I were to try to load a previous version after the most recent.
Posted: Tue May 14, 2013 2:46 pm
yes, c is the latest, only need the latest one of each.
anything listed as a is already in your tool :)
Posted: Tue May 14, 2013 4:58 pm
by engscott78
Mike,
I'm really not as stupid as you're thinking.
I must be dragging and dropping with the wrong hand, because this damn thing isn't updating.
All the updates show up in the drive, but when I check the firmware on the tool they haven't taken.
Any advice?
Posted: Tue May 14, 2013 5:10 pm
if they are sitting on the drive, they are not importing.
try rebooting the tool.
