Page 8 of 8
Re: ABS and Servic Brake System light
Posted: Wed Jun 05, 2013 9:41 am
by dreamer
Moving this up....
Any thoughts on my problem here?
Posted: Wed Jun 05, 2013 9:43 am
I'll have to get someone to look into this, as this has fixed everyone else....
Posted: Wed Jun 05, 2013 11:16 am
by dreamer
I didn't have any lights come on until after I put the inTune on. I checked for codes and there are none available.
Posted: Tue Jun 11, 2013 9:20 am
by dreamer
Any thoughts on this?
I put the truck back to stock and released the intune from the VIN. ABS and brake lights still on after a short driving period.
Until I put the programmer on initially, I NEVER had these lights come on. Tune the truck, and ding ding ding ABS and brake lights. Now they won't go away. It's obvious that something in this tuner as messed up the computer. Is there a fix for this or...?
Please tell me I haven't wasted $300 on the tuner, plus another ridiculous dollar figure to get the truck computer repaired/replaced.....
Posted: Tue Jun 11, 2013 10:11 am
if they are still there without the tune, it sounds liek a sensor failed, as much as it may look that way, a tune cant make a sensor fail...
Posted: Tue Jun 11, 2013 11:33 am
by dreamer
mikel wrote:if they are still there without the tune, it sounds liek a sensor failed, as much as it may look that way, a tune cant make a sensor fail...
That would be quite the coincidence then considering that the day I recieved the intune in the mail I tuned the truck, and went for a test drive to see the difference it made. On that very first drive after installing the intune, the lights showed up.
I must be very unlucky to drive home from work without any lights, install the tuner shortly after, and have the lights on right away.
Posted: Tue Jun 11, 2013 11:51 am
by dreamer
- IMG_1362.PNG (182.22 KiB) Viewed 3380 times
Onstar shows that there isn't anything wrong with the ABS system. Yet my lights still show up. Is this just a product of a software bug? I guess I don't know when this evaluation was taken. (whether it's done while driving down the road or what)
Posted: Wed Jun 26, 2013 11:41 am
by dreamer
Bringing this back up as I still have to deal with the ABS and Brake lights coming on.
Has there been any time to look into this issue?
Posted: Fri Jun 28, 2013 5:35 pm
by Rmejia
i have the same issue, installed the intune and a couple miles into the test the abs/brake lights come on my truck is an 05 chevy silverado 1500 crew cab 5.3, is there a fix for this??
Posted: Mon Jul 01, 2013 10:22 am
Rmejia wrote:i have the same issue, installed the intune and a couple miles into the test the abs/brake lights come on my truck is an 05 chevy silverado 1500 crew cab 5.3, is there a fix for this??
did you adjust the tire size?
Posted: Mon Jul 01, 2013 6:54 pm
by Rmejia
mikel wrote:Rmejia wrote:i have the same issue, installed the intune and a couple miles into the test the abs/brake lights come on my truck is an 05 chevy silverado 1500 crew cab 5.3, is there a fix for this??
Yes i adjusted it to the 315/70/17, i should have mentioned that sorry
