Page 9 of 10
Posted: Tue Jun 12, 2012 9:12 pm
by BIGDADDY1969
Normal is just like it says put it in drive and go ... Sport/Tow is whichever ur veh has sport mode or tow mode button .. U set two diff settings for when its in drive n when u push ur sport or tow mode button which ever ur veh has.... THEN within either one theres WOT (wide open throttle) adjustments and part throttle( not wide open ) adjustments ... Once u grasp that its not so confusing ..
Posted: Tue Jun 12, 2012 10:12 pm
by Satch606
I guess its gm generic then because the TBSS doesnt have different modes.
Posted: Wed Jun 13, 2012 3:45 am
by thilowvg
Mike, I just recently downloaded the tcm support for my intune. Thank you. I am a bit confused about the calibrations. My vehicle is a 07 Escalade and on the diablo tune. In TCM I have firm or hard shift options as well as normal and sport/tow. In both of these, there are just rpm adjustments. I read on this thread other users talk about shift pressures and torque management. What am I missing? Do different vehicles have different calibration options? Am I able to just change shift points at RPM points or can I also change the firmness of those shifts (other than just choosing hard shift)? For example, there are several options like 1 >2 and I can just change rpm. When I choose the hard shift, it does not seem to change much...actually before I got the TCM update, on the diable tune, it seemed to shift much firmer. I would just like to get the most out of this feature and would like my shifts to be firmer.
RE: Re: Anyone want to play with TCM support?
Posted: Fri Jun 15, 2012 1:52 am
by rdss
It's on page seven of this thread about half way down the page and I'm pretty sure it auto updates now as well to that version anyway.
Posted: Fri Jun 15, 2012 3:58 am
by BIGDADDY1969
It auto updates and includes TCM in it now .. It auto loaded mine anyways when connected it to puter ..
Posted: Fri Jun 15, 2012 11:53 am
by rdss
Like stated above you need to have the latest software already loaded into the tool prior to dropping the TCM file found on page seven into the inTune drive. Also, like Mikel has stated, the full version is released and will update to your tool automatically. From what I have read, it takes quite a while to get everything downloaded to the tool so be patient.
Posted: Fri Jun 15, 2012 1:13 pm
everything is released and available for auto update...
Posted: Sun Jun 17, 2012 7:07 pm
by rthms20
What's a good setting for torque management? I don't wanna break my truck.
Posted: Mon Jun 18, 2012 10:57 am
by Oldsaltydog
Tune it till it bangs gears then back off 1 or 2 numbers
RE: Re: RE: Re: Anyone want to play with TCM support?
Posted: Wed Jun 20, 2012 1:54 pm
by Oldsaltydog
Tcm calid may not b supported they had to add mine
Posted: Wed Jun 20, 2012 3:34 pm
ctxaggie wrote:
mikel wrote:everything is released and available for auto update...
I'm still unable to find TCM in my parameters. I even reset all parameters on my custom tune but still no luck. Any ideas on what I'm overlooking?
get me your VIN please.
Posted: Wed Jun 20, 2012 7:14 pm
by BlackZ71Silverado
Finally home and got this updated and installed.....Works GREAT, much more adjustable and noticable than SuperChips offers.
So far I have my settings set at -4 for gears and 2- WOT. Didn't adjust RPM at all though. Still unpacking from vacation.
Posted: Wed Jun 20, 2012 8:58 pm
by rthms20
I already got the tcm update but not the latest update. Should I return to stock before doing this auto update?
Posted: Wed Jun 20, 2012 10:20 pm
no worried if you're already on 1r02a.
Posted: Fri Jun 22, 2012 9:25 am
he's checking it out.
