po121 after ported throttle body and manifold
RE: Re: RE: po121 after ported throttle body and manifold
yeah, cuz as I mentioned over on your ls1tech post, that minMAP and maxMAP parameters are not available in the tune file/template, so since they're not there, can't adjust anything for 'em... so all that could be done was to disable the trouble code...
supercatxr7
Post by supercatxr7 »
I want min/max MAP support! I want min/max MAP support! I want min/max MAP support! I want min/max MAP support! I want min/max MAP support! Just kidding....
Oh, and TCM support would be nice too!
2006 Monte Carlo SS 5.3 V8
U7191
rletzgus
Post by rletzgus »
Ok Help me too. I put a 80MM throttle body on my GMC 4.8. Throttle response is phenominal. But I always get the PO121 code also. I put the stock back on and the PO121 never shows. TPS is good by way of multimeter check. I tried the "relearn" but that made no diff. I increase the TPS v. MPH setting, that made is shift better and the code show less. I got the settings maxed at 40%. If i go higher the thing will go 35-40 in 2nd at part throttle. ?????
2001 GMC Sierra
4.8L
K&N FIPK Cold Induction
Headers
2.5" duals with Delta 50 Flowmaster
B&M tow shift kit on 4L60E
Predator U1798 ver 9r15
MSD Ignition MSC Multispark coils
