to those that know
Shaken
Post by Shaken »
Until you do I would not mess with adjusting your fuel till you install one or take it to a shop with a dyno that has a wide band. Tail pipe one work but from what I hear you want to be as close to the upstream o2 as possible to get the best reading. When you adjust the A/F you will might see 10 more ponies from posts I have read.
2003 Mach 1 K&N cai w/screen
Accufab 60mm Twin TB Steeda Tri-ax
Predator custom tune +1 lean 2k-4k, +1 lean 4k-7k
AFR 12.6-12.8 3/8" Roy Spacer IAC plate
Bassani O/R X 2.5 flowtubes to Delta 40's
w/factory tail pipes
ghettofied
Post by ghettofied »
another pull with abit more fuel considering o2 voltages from previous run
will take some out seeing that its a bit rich now im aiming for around .6 volts
i am wondering about those o2 readings tho seems like bank 2 is slower to respond or generally less responsive i am going to swap bank 1 and 2 see if it persists if so ill through an o2 in it
ghettofied
still curious about those o2 readings havent tried swaping left to right yet might do that today if my boss lets me pull it in :roll:
any how
spark- 2.5 , 4
fuel- 2.5 , 3.5
Return to “Predator Ford Gas”
