Page 2 of 4
Posted: Wed Nov 05, 2008 10:07 pm
by carter242000
your stock timing should be 10 degrees so id make sure that is what its set to and try a higher octane fuel. also change the plugs asap. check your spark advance setting on the predator and make sure the number is 0 and not plus or minus anything. if still not fixed id call the tech line if you dont get any additional responses. i know theres a lot of guys on here that know more than me so hopefully theyll chime in.
Posted: Wed Nov 05, 2008 10:36 pm
by LuisMunoz
how do i check what degrees my car is at, are those the numbers i mentioned earlier that came up on the tuner while logging... the highest actane around here is 91, even with 91 octane it still doesnt work, should i try some octane boost or something??? The settings on the predator all say 0 for spark advance, but since iv also been reading around this forum that if you cant get 93 octane where you live, you should retard the SRK ADV by two degrees so that it can run the 93 octane tune that the predetor comes with, should i still leave the settings to 0???
and please anybody that can help please do!!!!
Posted: Wed Nov 05, 2008 10:46 pm
by carter242000
if it says 0 now then i would try retarding the timing a little at a time and see if it goes away. the timing may have been set incorrectly before you got the car, but try retarding it first...
Posted: Wed Nov 05, 2008 11:05 pm
by LuisMunoz
ok tomorrow ill start at -.5 and work from there... if NONE of this works should i just take it to a ford dealer and let them figure out what is wrong with it
Posted: Wed Nov 05, 2008 11:09 pm
by carter242000
yea i would take a shop you trust....dealerships are usually more of a rip off but id take it somewhere. good luck
Posted: Wed Nov 05, 2008 11:17 pm
by LuisMunoz
I have a friend who drag races mustangs and has his own shop and does his own work on his cars, his fastes stang does 8.9 in the 1/4 and slowest does about 10.5, ill have him take a look at it
Posted: Wed Nov 05, 2008 11:23 pm
by lazorrazor
2004 Must GT, Man trans, 2valve.
I'm runnin a BBK CAI in the fender also have a 70mm TB....u7146 Pred 93 Oct Perf tune, car runs quick and sounds great, check the installation, sounds like your either leaned out or timing is way off. Could be many things...MAF prob? Idle ok?
Posted: Wed Nov 05, 2008 11:26 pm
by LuisMunoz
it idles kinda weird, sounds like if i were to be lightly steping on the gas and letting go over and over
Posted: Wed Nov 05, 2008 11:28 pm
by LuisMunoz
Oh and i also cleaned the MAF and nothing changed, do i need a new one or what???
Posted: Thu Nov 06, 2008 12:09 am
by Mindcrime13
check, the fuel filter maybe its clog, and not enough gas is making it into the engine. just a thought
does it make the knocking all the time? or only on idle, slow acceleration, or highway speeds?
eres de puerto rico de casualidad?
Posted: Thu Nov 06, 2008 12:26 am
by LuisMunoz
I already replaced the fuel filter, it usually does it all the time,i cant really tell if it does at highway speeds since i cant really hear it over the flowmasters, sometimes when im at a complete stop it starts to do that and i can hear like a hss hss hss kinda sound but that most of the time only does it for a minute or so then just goes away and comes back later i think it might just be the fan though, i can olso hear a ticking sound from the engine, and when its cold you can hear that ticking through the mufflers, but usually only when its cold.
Y no chico yo soy de Cancun, X ke la pregunta???
Posted: Thu Nov 06, 2008 1:57 am
by Mindcrime13
try an octane booster, if it cures it, then you gotta adjust the timing
oh ok jaja, es q conosco a muchos luis muños por aca, es un nombre comun aqui.
Posted: Thu Nov 06, 2008 10:00 am
by Shaken
Your problems started after your mod install? If so I would check there for a unmetered air leak. You should also check your TP voltage and make sure it is below 1 volt you can do that with your Predator. I know the TP is not adjustable but you can loosen the screws and adjust it a little bit. If you didnt have this issue before your mod install you might want to put the factory stuff back on and see if you still have a issue. If you want to use your Predator 93 octane tune you will have to retard your timing settings for WOT maybe as low as -10% in both RPM ranges. You state you have limited knowledge of cars you might want to consider having these mods professionally installed.
Posted: Thu Nov 06, 2008 3:13 pm
by LuisMunoz
well the only mod i did myself was the CAI.. the others were done by a shop that i trust... my problems started before i had the mods, when i put the flowmasters on and removed the cats the problem continued
Posted: Thu Nov 06, 2008 5:40 pm
by LuisMunoz
the sound coming from the engine was noticable before i installed anything, after i did the flowmasters the sound got louder, while trying to figure that out i discovered that my intake manifold was cracked at the bottom so i replaced it with an typhoon intake manifold, i didnt want to install another factory plastic one, thinking that that was my problem all along. after the manifold install the sound quieted down some but not much, you could still tell it was there pretty easily, after the exhaust install is when it got louder again like before i did the manifold change and it hasnt changed since
