Old tuner stolen before returning to stock
Re: Old tuner stolen before returning to stock
there is a tune called modify stock that doesn't change anything unless you make specific adjustments when loading it.
Thanks Mike! It seems like modify stock worked perfectly, no lights for the past 2 days!
give me the device serial number and I will reset it for you so you can use it on another vehicle.
actually I found it from your email, please update it to reset it.
Hello
I have a similar problem
I bought a 2014 Mustang 3.7L Convertible last year.
I accidentally got a Diablo Sport I3 for a good price.
I wanted to use it, and it told me that my car was previously tuned with a Diablo product and must be returned to stock before I can tune it.
Could you help me get my car back in original condition so that I can use the tuner?
load this to the car then it will be back to stock and you can tune from scratch
Hello
I tried it, but unfortunately it doesn't let me select a restore backup.
What can I do?
What can I do?
there wont be a return to stock option.
Load the file i provided to the i3, let it import the file, then when you connect to the car and click tune vehicle it should prompt you to load the update I provided, which will set it back to stock and from there you can select any tune and load it.
Hello
Thanks, it worked.
Thanks, it worked.
