no power after trip to the dealer
swamplandkarl
RE: Re: RE: no power after trip to the dealer
Post by swamplandkarl »
Is there someone at Diablo that can help me with my problem and will follow threw ?????????????????
I would like to get this issue resolved.
Thank you??????????????/
swamplandkarl
<<<<<<BUMP<<<<<<<<<<
sohfast94
Post by sohfast94 »
I didn't tell you to say anything about the FICM. Just get them to re-progrma the truck
Insert Clever comment here...
swamplandkarl
So the dealership would just load the same current ford factory flash to the PCM?
Sorry but I am really not understanding you and what I am trying to get the dealership to do?
sohfast94
Post by sohfast94 »
All you need to do is complain that there is a lack of power after you got it back and they will do everything else.
swamplandkarl
OK I will give it a try as the truck is still at the dealership............
swamplandkarl
OK got the truck back loaded my 100hp tune and still the same thing not much power dealer says they cant do anything else.......
Is there anything like a different tune or something?
Is my predator now useless, I have only had it less than a month?
What can be done to fix this back to they way it was?
tuningss
Post by tuningss »
post your new cal id and both the original backup and last tune written so Brian has something to go off of.
http://www.tpctuning.com
swamplandkarl
OK I will be glad to do this but I will need to know how?
I have no way to connect to the tool....the dealer I bought the predator from can he do this?
New Calid id#vxap2n2 old Calid# vxam7n3 U7165 rev"9r05
the tune is the 100hp that is in the tool from Diablosport......
The orignal backup is now in the tool how would I get that and send to them?
tuningss
Post by tuningss »
Try this. This is the latest updated tunes for your particular cal id. http://www.diablosport.com/index.php?na ... ic&t=10558
Refer to this to learn how to import/export tunes.
http://www.diablosport.com/index.php?na ... pic&t=4405
swamplandkarl
OK guys I am at a loss on where to go now as the dealer has told me that that he has done everything he can do.
Is there anything else I could try to get the predator to work like it has in the past?
When I load the 100hp tune its way down on power and and surges and bucks while crusing and around 1000 rpm jumps real bad.
Will you be coming out with a new crom or fix for this?
I will say that the one time I did get to use the Predator it was awsome but now its useless until they get a fix for this problem.
Brian could I call you directly to discuss?
Please reply,
Thank you,
swamplandkarl
>>>>>BUMP<<<<<<<<<<<
swamplandkarl
up date for all that might be having the same issue as I am................
Diablo customer service has told me that there coders are working on this issue and should be releasing a new crom to correct the problem, the new crom should fix the issues with the lastest calid ID released from ford motor company causing these issues mentioned in this thread (crossing my fingers)...........
Thanks to Diablo Sport for the continued support..............
I cant wait to get my can of whoop azzz back........
swamplandkarl
Brianm, aka sohfast94.............
Can you verify this?
sohfast94
Post by sohfast94 »
Check your email....
