New beta for unsupported 04 and 08, tune changes as well
- chefred112
Hey Mitch,
here is where I got my cutout setup...
http://moesperformance.com/index.php?ma ... ts_id=1425
you can start out cheap and get just the cutout tubes (they have plates to bolt up the holes), then get the electic valves later..
As for gears, I did 4.56's when I first started modding. They were great on the street. But the more I modded the more I realized I was running out of gear in the 1/4.....that's the reason I went to 4.10's, and as I modded to where I am now, it feels just as quick outta the hole as the 4.56's...
fred
fred
-Fast Freddie-
05 Hemi QCSB
392 - 232/238 cam /heads/lt's/true duals/dual e-cutouts/cai/efan/3.92 gears/2600 stall verter/180 tstat/cat deletes
old 5.7- 214/218 cam/heads/lt's/true duals/dual e-cutouts/cai/efan/4.56 gears/2800 stall verter/180 tstat/cat deletes
05 Hemi QCSB
I'd like to try out this new CROM but it's suppose to rain all day today into tomorrow then possibly snow/sleet tomorrow night
Fred, that looks like the exact exhaust setup (minus the cutouts), that I put on and the same way I plumbed it too... I'm thinking of the cutouts sometime down the road too.... Lookin good.
Not sure why your kr is so high, crappy fuel maybe, maybe truck needs some more fuel down low.~RAM~ wrote:Ok so I jus installed the tune, an did a couple wot runs, I never touched the trans params, an everything in pcm params cept spark,added 11% , 0%, and leaned up 4%
And from a dead stop I mash the gas an the low end power seems to be better than the last tune I had, but in first gear an barely into second I had about 6.00 st knk retard at about 2.3k rpm an about 3k dropped to 5.00, 3.5k at 4.50,and 4k, 3.50 an shortly falls to 1.00 after bout 5k rpm, after shift all the way up to 80 mph no more than 1.50 st knk retard.
My question is, why is it so high in first gear? Is it the burn out? Would like some info.
An the 1-2 gear is nice now no pause just strait shift, an a longer tire scratch, I believe johan is on to somthing
Keep up the good work.
~Mitch
Yeah i did those changes on a truck here and it seemed to help it quite a bit so i thought i would add that into the regular tunes.
Johan< @ >DiabloSport.com
Diablosport INC
Research & Development
Diablosport INC
Yeah you prolly had the older calid's for your 08, these new ones came out like 2-3weeks ago.spin2008 wrote:Johan, I recently loaded the DB for the first time last weekend (12/6) on my 08 and everything was accepted fine (stock with exception of cai). Had to do a calibration update only. My question is did the new calids come as part of that download I did and that may be why everything was accepted into my vehicle without problems or just lucky for my particular vehicle? Should I be trying the new crom for more improvements or is that just for the other 08 that had different calids/unsupported ones from mine? So far there has been harder shifts and improved acceleration--all things running/shifting smooth. Very impressed so far with 93 tune/difference.
You can try the new crom and shift improvements where made the those tunes.
You will probably have to do a calibration update when using the newer crom as we will update you to the latest dodge cal.
Diablosport INC
Diablosport INC
Re: RE: Re: RE: New beta for unsupported 04 and 08, tune cha
If you are using a custom tune this update will only address the key cycle thingy in the 05's .chefred112 wrote:I downloaded the file..will this affect the custom tune I have on the truck now? it sounds like the steps to apply the crom file is:
1) Set truck back to stock
2) connect tuner to pc, start ds downloader, send Crom file to tool
3) connect tool to truck and reprogram my custom tune...
sounds right?
Fred
Diablosport INC
Diablosport INC
- chefred112
Johan, I made changes to the tcm parameters (shift points), but I didn't see the tcm load bar (like the pcm shows)... at the end my tuner did show tune loaded successfully but I never saw the tcm portion load up...
-Fast Freddie-
05 Hemi QCSB
05 Hemi QCSB
acarroll89
So if we are using a custom tune the better shifts will not take affect? Im using a 2nd prime delete I got from hemifeverjohan wrote:If you are using a custom tune this update will only address the key cycle thingy in the 05's .chefred112 wrote:I downloaded the file..will this affect the custom tune I have on the truck now? it sounds like the steps to apply the crom file is:
sounds right?
Fred
Black Front Mount Turbo Hemi Ram
IEMS3 Tuned
IEMS3 Tuned
Thats odd, did you go back to stock before the update?chefred112 wrote:Johan, I made changes to the tcm parameters (shift points), but I didn't see the tcm load bar (like the pcm shows)... at the end my tuner did show tune loaded successfully but I never saw the tcm portion load up...
The first install did you see the tcm bar during the install?
Diablosport INC
Diablosport INC
Right, cause you are over writing the tunes with your custom tune.acarroll89 wrote:So if we are using a custom tune the better shifts will not take affect? Im using a 2nd prime delete I got from hemifeverjohan wrote:If you are using a custom tune this update will only address the key cycle thingy in the 05's .chefred112 wrote:I downloaded the file..will this affect the custom tune I have on the truck now? it sounds like the steps to apply the crom file is:
sounds right?
Fred
If you want, send me your current tune and i can change it.
Diablosport INC
Diablosport INC
Yes but i am looking into something here on that, if you want send me your last tune written and your tcm calid and i can hook you up with some custom tunes for now.~RAM~ wrote:Johan,
Does this crom support tcm params on the 05s?
Also I already have 11% in the low end.
So I guess ill add more?
Diablosport INC
Diablosport INC
