U7130 Extreme RKL 200hp & Perf Stacker tunes Downloads
sawboywv
Post by sawboywv »
IF I WANTED THE "RKL" WITH OUT STACK , SO MY U7130 WOULD NOW HAVE 4 PERFORMANCE TUNES,
ALL I WOULD IS DOWN LOAD ABOVE PROGRAM?????
duallydave
Post by duallydave »
plug ur tooner in to the truck and go to options and there should be a option for info and it will show your calid,do u have the ds loader aplication?it on the dloads page.u will be happy when u get the custom tunes in there.
04 l/box.predator quad race x2 cammander.bhaf.6spd stick.
sawboywv
Post by sawboywv »
So should I ugrade to all the newest program updates before loading in the RKL? (R29)
Then, check the calid & load propper RKL?
ram2500
Post by ram2500 »
whats the difference between the pre r28 and post r28 revision? I have the u7130 model for an 05.
duallydave
look at the version when it boots up,if you have a number less than r29 use the pre 28 tunes and if u have r29 installed whcih is the newest version then use the post 28 tunes.i recomend getting the r29 version if u dont have it,its in the download section,then download the apropriate post r28 tune for the calid you have.then let the fun begin
morkable
Post by morkable »
HOw come I cant download the r29 tunes?
Kevin
duallydave
must be a setting on ur puter,do u have vista?i tried the link to the 12xxx and they were fine
ropnjessi
Can't Download
Post by ropnjessi »
The files will not download.
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
1ton03
Re: Can't Download
Post by 1ton03 »
ropnjessi wrote:The files will not download.
Files are fine, are you usung XP? just "right click" and click "save as"
Joe
RRAM
RE: Re: Can
Post by RRAM »
Files might be fine but are not accesable. The page is not available, whether you click the link or right click and saveas it. The ones for the pre29 are there. All the post 29 are not. Maybe they found some thing and have to change stuff.
Reg
2005 3500 Quad Cab Laramie L/B
Predator, AFE stage II, boost fooler
Pillar Mount gauges Billet low stall TC
duallydave
RE: Re: Can
weird i could have sworn i tried them the other day and they worked,to bad his calid wasnt 15xxx,i could email them.i saved all the tunes even the first r28 puffers.
goose2w1
Difference between 200HP toons?
Post by goose2w1 »
This might be a question of extreme ignorance but I have to ask before I try them. What exactly would the difference be between the Extreme RKL puff tune w/ no timing added and the Extreme RKL puff stack tune w/ no timing added. Neither of them have any timing. Just wondering which might be better to try with my Hot Juice first. Thanks for any insight.
Rocksolidcummins
RE: Difference between 200HP toons?
Post by Rocksolidcummins »
have tunes loaded onto predator and WOW these are some crazy tunes.
thank you Johan for giving me something so awesome to play with, i will treat it with the respect it deserves, lol
I just downloaded the proper tune file for my calid, uploaded to predator i still have regular tunes - tow, perf, ext, than i go to custom tunes and i have four more, rkl, rkl puffer, ext puffer, rkl no tim
2004 2500 Cummins Reg Cab - NV5600 - Southbend - DS Predator w RKL - HE351C - Head Milled .020" - ARP - 40% Nozzles - Gone
2010 Sierra Denali - 6.2 L - rusty but clean, comfy but mean.
blackdodge23
Post by blackdodge23 »
I tried a few times today to download this to the ds downloader,it seems that it does not recoinize the file on the desktop of my computer without it being a crom file.How can I fix this?
You need to hit send tune file to Predator, not send crom file to Predator.
