It is possible you are collapsing it. The only time I have been able to monitor that is on the chassis dyno and have someone watch it. Is it possible to replace it with a plastic one? Maybe even a powerpipe...
Kev
installed MAFia, engine cutting out around 4500rpms
recharged95
RE: installed MAFia, engine cutting out around 4500rpms
I can't imagine the tube collasping--it's 1/4" rubber, short radius bend (one of these). And that I cut off an additional 2 inches one side. It's pretty short (like 3x3).
I'll try putting a coil inside to keep it from collapsing if it is... I'm going to experiment with the intake setup and bypass (maybe that too as I have the standard bosch 114 bypass--maybe too small & leaking?).
Anyway, here's the latest run I hadon MAFia setting 3 with the MAF max voltage set at 4.98. It's really noisy since this wasn't on the track or a dyno, so I was losing traction a lot.
Interesting that the 2nd gear pull, it did not flat line this time so i;m getting somewhere.
I am a predator U7137 but I have 04 car (02 Dodge 5.7 year: 2008 and 02 grand cherokee year 2007 and 2008). I used the predator in a car but I can not use the predator in the other car. Please can you helpme How I can use the predator in differents cars?
Re: RE: installed MAFia, engine cutting out around 4500rpms
You can only use the Predator tune in one car at a time. You must restore original backup before moving it over to another vehicle. You can use the diagnostic features on multiple vehicles...best wrote:I am a predator U7137 but I have 04 car (02 Dodge 5.7 year: 2008 and 02 grand cherokee year 2007 and 2008). I used the predator in a car but I can not use the predator in the other car. Please can you helpme How I can use the predator in differents cars?
Kevin@Diablo
