Page 2 of 3
Re: RE: 300 srt/ Knocking/Pinging
Posted: Sat Apr 11, 2009 7:12 am
by Mike_Levy
Quick wrote:
When you get your catch can do not use heater hose, it won't stand up to the oil. You can expect to catch about 10 ml per 500 miles.
Since when? I've used heater hose on both my SRT8s and haven't had any issues with it not standing up.
10ml per 500 miles is a low estimate too. I've filled the BT can 90% in just over 3000.
Posted: Sat Apr 11, 2009 11:00 am
by crf450rr
Posted: Sat Apr 11, 2009 1:38 pm
by Quick
It takes a good while for the heater hose to start collapsing (we're not talking any sort of huge vacuum). It's gradually going to rot/get softer and softer from the inside due to the oil deteriorating the rubber. If you can't find hose specifically for PCV then rubber fuel line will do just fine (Napa has it in bulk -- 1/2" inner diameter). It's what it's lined with that's impervious to the chemicals. That's why BT had to change the heater hose they originally shipped their can with.
10 ml to 11 ml per 500 is typical. I kept careful track measuring in a beaker for over 10K and managed to get a few other SRTs to do the same. Some collected more, most everybody was right between 10 ml and 11 ml. It's true that no one collected less. You had some huge knock problem too right? I'm not convinced that your engine is exactly representative. No doubt it makes a measurable difference eliminating it when tuning for more performance
Posted: Sat Apr 11, 2009 9:41 pm
by SRT8_T
LMAO!! i was trying to get one yesterday and they said they make no such one for my car. i read this post just now and called them... 2 in stock!! LOL thanks again.
Posted: Sat Apr 11, 2009 9:43 pm
by SRT8_T
crf whats up man your on here to huh. got the car dialed in pretty good
Posted: Sun Apr 12, 2009 10:36 am
by crf450rr
Yep, I'm here as well...
Posted: Sun Apr 12, 2009 12:37 pm
by Mike_Levy
Quick wrote:You had some huge knock problem too right? I'm not convinced that your engine is exactly representative. No doubt it makes a measurable difference eliminating it when tuning for more performance
Yes, on both of my 6.1s, which leads me to believe that its common. On the new top end, there has been minimal knock, never more then 1.5 degrees, and it still throws ALOT of oil into the can.
RE: Re: RE: 300 srt/ Knocking/Pinging
Posted: Sun Apr 12, 2009 1:42 pm
by SRT8_T
question... you guys think i should add more fuel to eliminate knock as much as possible. it spikes to 3 at 5% rich but thats it.
also there is jet throttle body spacer for sale for 55 bucks is it worth getting?
Posted: Sun Apr 12, 2009 3:03 pm
by Quick
I think everyone agrees that the TB spacer does not do any real damage (but it probably does impede air flow a bit). So if you want to pay $55 for a whistling sound it shouldn't hurt anything.
Posted: Mon Apr 13, 2009 4:52 pm
by SRT8_T
ok so im at 15% rich knock is at 2.5-3 but when i shift sometimes it spike to 5 or 6 and i cant get rid of that why? i thought i had the tuning dialed but when i went out today i had to keep adding fuel. any recommendations? quick what is your settinggs at we have the same mods maybe i can use yours as a base to start over from.
Posted: Tue Apr 14, 2009 3:09 am
by Quick
Well... I was up around 15% I think. I actually tuned with a wideband and was looking at AFR. It was about right around 11.9 - 12.1 I'm not exactly sure how much fuel that was because I saved the tune to the pc and then reloaded it to the predator as a custom tune a couple of times and didn't write down the changes I had made before saving to the PC. (it's a long story. I was trying out different approaches. One was tuning to about 12.6 AFR and pulling timing as necessary and the other one was tuning to about 12.0 AFR. I kind of gave up on the 12.6 at some point. Unfortunately I can't remember if I pulled a degree of timing in one or two ranges either.
Since then I've been running a CMR tune for a good while (that is around 12.0 AFR also). Mainly to get the shifting/torque management just where it feels good to me. (I guess that wasn't much help for you).
Maybe gas and likely a lack of a catch can may have something to do with it. When you have a little layer of oil in the manifold it's not going to get fed into the cylinders real evenly so the knock retard may not be real consistent from day to day.
Don't be shy. Try throwing like 22% at it and see what happens. Worst case if you go way too rich it's going to smoke a little bit and you'd lose a little power. Nothing to worry about for a little while or a couple of days. After that you can try pulling a degree of timing and back off on the fuel.
some knock issue
Posted: Tue Apr 14, 2009 1:00 pm
by Rick184u
so i just got my predator and the C&L Air intake and love it for my 2008 srt8 6.1 challenger. however im getting some knock between 1-2nd and 3 gear while shifting or stomping the gas . i did some data logging and the st knock goes up to 5.50 and the LT gose up to 3.50 which im told is high. should i add fue to rich or lean or decrease timing? im running the 91 cai tune but running 93 gas what should i do. the gas i use is Bp amaco
RE: some knock issue
Posted: Tue Apr 14, 2009 7:56 pm
by SRT8_T
i have the exact same problem and cant seem to tune it out. by adding fuel i elimated most of the knock during wot thru the gears but between shifting and stomping the gas is where i cant bring it down. i am gonna try pulling a degree of timing.
for you rick try adding fuel first.
Posted: Fri Apr 17, 2009 12:02 am
by Rick184u
well i try adding fuel it did not work, i work it up from 5 % all the way to 20 % and that did not work, i took off timing by - 1 and restart with the fule that did not work its just got more bad. so what i did was reinstall the stock tune, and modified the stock tune the way i want, like the rev limiter and the speed limiter the transmission and the tire size and wow she running good i did some data logging and the st knock goes up to like 2 and back to zero and the LT stay at zero when stomping it and changing gears. and best of all the knock is gone, i am still using 93 gas and she is running great here in Miami on Thursday is race night and i been kicking some ass i have a 2008 srt8 6.1 challenger with C&L Air intake and more to come soon.
Posted: Fri Apr 17, 2009 12:51 am
by SRT8_T
sounds like im gonna do the same thing. i hear the catch can will help alot with the knock issue.
