Page 2 of 2
RE: U7193 Logging 05 Avalanche
Posted: Tue Jun 30, 2009 3:28 pm
by Iceberg
I uploaded the wrong file before. The coreect one is above.
Re: RE: U7193 Logging 05 Avalanche
Posted: Tue Jun 30, 2009 3:56 pm
by 06MonteSS
Iceberg wrote:I can get on a road where I can drive at 75mph for a while. This puts me in the 2000rpm-2200 range. Should I log this way or should I log in 3rd?
yeah, if you can go 70-75 steady so that your rpms are 1800-2200, that works...
and if it's that hot there already man, don't kill yourself... do it with the A/C on, don't worry about it...
sounds like you probably use it most of the time anyway with temps like that... daaaamn!!
RE: Re: RE: U7193 Logging 05 Avalanche
Posted: Tue Jun 30, 2009 8:22 pm
by 06MonteSS
ok, looked at your log....
your average ltft's are at 2.7xx and 3.6xx... so for now, I'd say to go -3% on your injector slope setting... install that modified/adjusted tune setting, put on about 75 miles, and then do a new steady driving/cruising log... and select the appropriate throttle/accelerator pedal position parameter this time around....
then post up the new log and let's have a look at it...
Re: RE: Re: RE: U7193 Logging 05 Avalanche
Posted: Tue Jun 30, 2009 8:59 pm
by Iceberg
06MonteSS wrote:ok, looked at your log....
Thanks! I will keep you posted
new log
Posted: Thu Jul 02, 2009 3:07 pm
by Iceberg
I did another log with the right parameters set. Have not adjusted injector slope yet.
Latest log
Posted: Sun Jul 26, 2009 1:36 am
by Iceberg
Here is my latest log. I adjusted -2 from my last log and now this one says to adjust another -3. Does this seem right?
RE: Latest log
Posted: Sun Jul 26, 2009 1:56 am
by 05Z71
Iceberg, what part of Texas are you in bud?
RE: Latest log
Posted: Sun Jul 26, 2009 11:59 am
by Iceberg
I am in Austin.
RE: Latest log
Posted: Wed Jul 29, 2009 12:54 pm
by 06MonteSS
checked out your log...
I would go another -2%...
you are saving the change after you adjust the slider, right? adjust it, press the center button to save it, then install the tune with the saved change???
cuz the ltft's are similar to your first log I had checked out... doesn't seem like your previous adjustment took hold...
RE: Latest log
Posted: Wed Jul 29, 2009 1:04 pm
by CANUCKPREDATOR
any differences in the weather between the logs? temp and humidity will effect results.
Re: RE: Latest log
Posted: Fri Jul 31, 2009 6:44 pm
by Iceberg
06MonteSS wrote:checked out your log...
I will make the adjustment this weekend.
Thanks!
