U7194
Dirkdiggler90504
getting errors when? when trying to install the tune to the truck, or when trying to import the custom tune into the predator?
did you hook up to the truck and let it make a backup copy of the new original stock tune??
if not, you have to... you can not import a custom tune into the predator if it hasn't saved a copy of the original backup first.
Dirkdiggler90504
Dirkdiggler90504
well according to the software on my PC i do get a message that says the program has been downloaded to the tool successfully. but when i try to use the tool for anything afterwords is says custom tune error 09 or something like that. then after i erase extra tune everything works perfect again
2007 Tahoe 3LT Gibson Exhaust Diablo Predator
Are you using the LS2 interface or DSDL?
Dirkdiggler90504
Dirkdiggler90504
Sounds like you are using DSDL??
Did you maybe use an old DSDL to pull the backup file?
Dirkdiggler90504
So, you used the LS2 interface to export the backup you sent me, and to load it to the Predator?
And it loads to the predator OK?
Dirkdiggler90504
Email me the tune you are loading please, and a copy of the current backup again.
Dirkdiggler90504
got em...
