Page 2 of 2
Posted: Fri Jul 10, 2009 4:13 pm
by larryc7777
mikel wrote:larryc7777 wrote:Hey Cookiemanster,
Ever hear of a thing called " thread jacking"??
I'm sure you are interested in an answer to your question but so am I. I don't have a Predator, so I'm not as interested, at this time, in a "stacked" tune result.
However, I also want to know if the posted dyno graph represents a EPP ONLY pull or a stacked pull.
That pull was with a 100% bone stock 06 F250 6.0 with the puck on the max (100HP) setting.
That's impressive!! Were you able to track down any info on the 6.7 Dodge results?
Thanks for the info.
Posted: Wed Aug 05, 2009 6:42 pm
by larryc7777
Well, after 1 aborted install attempt (wrong connector cable which Mike handled immediately, thanks again Mike), I now have my EPP working on my 2009 Ram 2500. I don't have access to a chassis dyno but I DO have a Dashhawk that can datalog performance runs. So, I took my truck to my favorite little-travelled road & did some 1/4 accelleration runs. With the EPP set to 0 on the dial (just like stock I guess), the Dashhawk reported a best of
[email protected]. With the EPP set at 100%, the Dashhawk reported a best of
[email protected]. I think that I might have lifted too soon on that run because it is very difficult to tell when the Dashhawk reaches the end of the run. I would guess that the MPH would have been slightly higher if I hadn't lifted. But the reduction in ET is considerable from "stock" to "extreme".
Almost a full second reduction in ET is HUGE....especially on a 7000 lb truck!!
I also noticed my highway mileage was almost 23 mpg as reported by the onboard trip computer. I don't know how accurate that puppy is but it was reading more MPG now than it did before the EPP install. I had the dial set at about 80% during the highway driving.
Tomorrow I'll be towing my 8000 lb travel trailer and I'll be able to get some more MPG data to compare to the "before" figures. I'll post my results when I get back.
By the way, my truck is stock except for a S&B cold air kit and the muffler has been replaced with a piece of 4" straight pipe. The CAT, DPF & the EGR are still as delivered from the factory.
Posted: Thu Aug 06, 2009 9:52 am
Wow, I'd love to see you reproduce those times at a dragstrip, very impressive.
Posted: Thu Aug 06, 2009 1:42 pm
by concoursd
Your MPG calculator is garbage once you install tuning. Always to MPG calcs when you fill up.
Posted: Tue Aug 11, 2009 2:22 am
by larryc7777
mikel wrote:Wow, I'd love to see you reproduce those times at a dragstrip, very impressive.
Well, the Dashhawk is usually within a tenth on ETs & a few MPH on speed. My closest 1/4 mile strip is more than 100 miles away. I probably won't make much of an effort to get there. HOWEVER, the Dashhawk IS very usefull for comparing changes made to the vehicle...especially when the runs are done back-to-back on the same road on the same day. So, even if the Dashhawk is off by several tenths from the actual times that would be reported by the timing equipment at the strip, the COMPARISON times generated by the Dashhawk should be accurate as far as indicating the amount of change between the "0%" setting on the EPP dial and the "100%" setting.
In regards to my towing MPG, I didn't notice much of a difference between my Before Puck mileage & my After Puck mileage. Probably about 1.5 - 2 MPG better than without the EPP. However, conditions were different between the comparison trips. I had considerably more wind to contend with on my latest trip.
Posted: Tue Aug 11, 2009 11:00 am
Yeah, I dont really question the accuracy f the Hawk, just makes it that much cooler to see timeslips....
Either way, glad it is working out for you.
