Posted: Fri Jul 31, 2009 1:06 pm
jvmorgan,
Looks like we have very similiar setups,
I had the same issue and Monte and I worked for months.
Then I changed my actual tires from original 245/70/17 to 265/70/17. After several more adjustments I managed to get my speedo right on the money (until I go over 77mpg. then its startes to act up the faster I go the more it becomes off when I'm doing 105 it says 114 hehehe). But up until 77 mph. it is dead on.
What I found is even with new (larger) wheels I still had to stay close to my original wheel size when manually setting the tire sizes.
I'm running one of the 87 Diablew tunes with slight changes to it in the tire size. My tire size is set at 245/66/17 with the actual tires on the truck being 265/70/17.
Some weird **it with the 07 light issues, but I would try adjusting the tire % factor by one digit increments. Thats what I did with a GPS to get all set. I have two tire setting one for each tune The 87 oct. & another setting for the 93oct. custom tunes.
Don't give up you'll get it just be patient..
Let me know if I can help, but I see you've got the best man working with you already.
