Page 2 of 2
Re: RE: Re: RE: Re: RE: 93 tune
Posted: Wed Aug 05, 2009 8:17 am
by duster360
newsrt4 wrote:so i went back to stock flash at WOt i will get anywhere between 10.8-11.00.
as far as the knock before i messed with it i was getting about 4-6.00 counts of knock between 3500-6000 rpm then pretty much went away once i retarded about 3.00 degrees.
i dont have the usd wire i just ordered and hasn't come in yet. so i wont be able to load up the data.
the wideband sensor is before cat.
im on stock fuel system and never changed out my fuel filter and have about 90,000 on my all fuel system
Stock tune sounds a little leaner than normal, everything else you've said sounds fine.
The "fuel filter" is made into the pressure regualtor and they're about $120. A simple fuel pressure test at WOT would varify whether or not there's an issue with the fuel system suppling enough volume.
RE: Re: RE: Re: RE: Re: RE: 93 tune
Posted: Wed Aug 05, 2009 2:18 pm
by newsrt4
how much fuel pressure should i have at wot and does the dsp log fuel pressure or do i need to hook up a gauge
Re: RE: Re: RE: Re: RE: Re: RE: 93 tune
Posted: Wed Aug 05, 2009 4:24 pm
by duster360
newsrt4 wrote:how much fuel pressure should i have at wot and does the dsp log fuel pressure or do i need to hook up a gauge
Fuel pressure should be the same as it is at idle--58psi +/-5psi.
No the PCM doesn't monitor fuel pressure. If it did, it would adjust for it. Attach a pressure gauge to the rail and I tape mine to the windshield temporarily.
RE: Re: RE: Re: RE: Re: RE: Re: RE: 93 tune
Posted: Wed Aug 05, 2009 5:31 pm
by newsrt4
okay
thanks for ur help
Posted: Wed Aug 05, 2009 8:55 pm
by Quick
duster360 wrote:Attach a pressure gauge to the rail and I tape mine to the windshield temporarily.
That's what he tells everybody... he's had all his gauges taped to the windshield for more than a year now. ghetto gauges.
just kidding
Posted: Wed Aug 05, 2009 10:31 pm
by duster360
Quick wrote:duster360 wrote:Attach a pressure gauge to the rail and I tape mine to the windshield temporarily.
yeah its getting hard to see out the windshield
