Page 2 of 2
Posted: Wed Nov 04, 2009 4:12 am
by fadhil
fadhil wrote:i have 2008 Yukon Denali and i still have sound of pinging even if fall my tank with 93oct if i use performance tune thant i chose 93 oct i will hear the pinging if i chooce the other tuning there is no pinging sound also after log and the 0.0 it still the pinging
sounds like some rocks rattling around in a tin can
if i use 85 oct tunig or factor tuning no painging
but i i use preformace tuning even after I adjust the injector & wot
can please answer me what is the problem
Posted: Wed Nov 04, 2009 4:15 am
by fadhil
Posted: Wed Nov 04, 2009 8:50 am
then it sounds like you are not using a high enough octane gas with the performance tune...
the gas you are using with the performance tune is too low of an octane, and the timing/spark advance in the performance tune is too high for it...
you either need to use a higher octane gas in your truck, or use the lower octane tune.
Posted: Thu Nov 12, 2009 7:07 pm
by solutionsix
Just an update that I am still looking at this. I decided to try fuel from a different station. I found out that the 93 octane BP is 10% ethanol even though its not displayed below the octane sticker on the pump. They recently added the 10% stickers to the pumps and now I'm concerned its the fuel. I am trying to run this tank down and am searching for a 92 octane pure gas to put in.
I'll post more logs once i am sure I have run the fuel out and have filled up with something different to review before i make any changes.
Posted: Sun Nov 22, 2009 11:12 pm
by pawngod
WELL..???? i am curious how its going as i as experienceing the exact same sounds....and yes..it is k.r. plain and simply too much timing advance on the performance tune. in my non expert opinion,
Posted: Sun Nov 29, 2009 2:53 pm
by mikeb33
I have a U7194 on order for my 07 Denali so I am interested too.
Can't you just modify the current tune to back off the timing a degree or 2?
Posted: Mon Jan 24, 2011 3:15 am
by HellHound
bizzady bump
