06 6.0 don't feel like it use to.
SCGt94
RE: 06 6.0 don
Post by SCGt94 »
silver i have something else i would like to try, i will send you something in a bit.
Don
2002 WS6
SILVERFORD2828
RE: 06 6.0 don
Post by SILVERFORD2828 »
Thanks for all the help. You guy's are great.
SCGt94
Post by SCGt94 »
we try we try :twisted:
sent
Don
2002 WS6
SILVERFORD2828
Got the e-mail i'll try it tonight. Work has picked up and i can't sneak away to try it. Thanks for working with me!
SCGt94
Post by SCGt94 »
no problem man, just let me know!
Don
2002 WS6
SILVERFORD2828
The bottom end still feels good (could use a bit more). The mid to top end felt better than before but needs to be about 2/3rd's more. But it didn't smoke a bit even when i lugged it. I am curious to what's happening are you bumping up fuel pressure,advancing the timing or what? Thanks again for your help.
SCGt94
Post by SCGt94 »
The ficm might be playing a bigger role now in these newer calibrations then they used too. That may be whats giving the issues now or for whatever reason, your trucks fuel system can not keep up. Try logging fuel pressure desired and actual with the predator and send me that log. That tune had more fuel and a different very aggressive ramp rate. If that thing still isn't smoking then there is an issue that i need need to look into further with these new calibrations. I actually have a truck coming in here probably next week.
Don
2002 WS6
SILVERFORD2828
while logging should i drive it hard or like i drive all the time? Will the log change while i'm pulling a gooseneck?
SILVERFORD2828
How much hp would it be if you maxed out everything that the 6.0 can handle? Keep in mind this is a F-350 reg cab drw w/ a 9' flatbed. What would be the first thing to break?
SCGt94
Post by SCGt94 »
they SAY the injectors and pump are fairly small on these trucks, but i have scene over 400hp on the stock fuel system and 770ft lbs.I would drive it fairly hard, i wanna look to see if your desired is matching your acutal pressure. If rail pressure begins to drop, it may indicate an issue. Everyone has mixed feelings on these trucks abilities, best to browse the power stroke forums. I believe vxcf9 came out due to the trucks not meeting emissions, hence greated restrictions on fueling for the newer calibrations. I did drive a vxcf9 truck and it did not feel any different then the previous revisions with a tune so..
Don
2002 WS6
tuningss
Post by tuningss »
Dons right, my truck made 447/770, but I had headstuds and egr cooler delete also.
http://www.tpctuning.com
SILVERFORD2828
I would love to put money into this truck BUT if they say these motors can't handle a lot then i don't really want to ruin it. Besides it's just used around the farm so it's no big deal. But it's funny to pull up beside some little 4 banger and blow smoke in on em', then smoke their arse in a dirty old flatbed with a sack of corn on the back. he he he
SCGt94
Post by SCGt94 »
the trucks are fun and get really good mileage. The weakest points are the head bolts. They stretch when boost levels start getting up there. Also the egr coolers crack and dump coolant into the chambers as well. A lot of people do ARP head studs and egr deletes and make some pretty dependable power on them.
Don
2002 WS6
SILVERFORD2828
Sorry i've been away from a computer for a couple day's. I have tried to log the numbers but i've been unsuccessful twice. Can you tell me how to save it and then put it on e-mail?
SCGt94
Post by SCGt94 »
it should save to the predator and then you can export it with dataviewer which can be downloaded here..
http://diablosport.com/index.php?module ... lay&pid=15
last one. This will allow you to view the log on a pc and give you the ability to send it to me.
Don
2002 WS6
