New trinity incremental with added calid support..
RE: New trinity incremental with added calid support..
gotta data log you can post up???
sure, what do you want to see? I got the regular stock, tuned +4 and two WOT's runs. Thanks for checking them out for me, Lew!
2015 Silverado 3500 HD Crewcab LTZ, Dually, Duramax/Allison 4X4
go to modify tune... go to spark advance, and set the upper rpm range to -3...
Which range? It gives me three choices. I set the lowest to -5 and next two to -3, previously. What should I do and thanks for checking out the numbers! How did they look to you? Really? I took out the Jet MAS as you recommended on all the runs.
like I said... the upper rpm range... which is the highest rpm range....
K, thanks, I'll set the other two to normal.
Fordlitenin
Re: RE: New trinity incremental with added calid support..
06MonteSS wrote:huh???Fordlitenin wrote:Since I am not a Trinity programer what is the latest crom update for the Trinity product? U7194, U7163 not sure. Is there not some kind of revision control on this?
if you have a ford, then you're in the wrong place... heh... and a 7194 update is not for you, that's for GM vehicles...
do you mean a U7136?? cuz there is no 7163....
latest trinity updates are the main update to 1r07... then the incremental update to trinity_u7136-1r07a_update.crom
Review previous questions and you would know that I also own a 2006 GTO which I have been trying several times to determine the latest update for the Trinity that I have. The one provided as the latest doesn't have all the backgrounds for the gauges(wallpaper). Since I don't know the differences between U7194, U7136, etc that you all use.
RE: Re: RE: New trinity incremental with added calid support
k... for the 06 gto... the trinity latest revision you need is the trinity_u7194-1r07a_update.crom...
Yeah, I believe you need 2 files: latest "Trinity Crom", and then the appropriate incremental update crom (u71xx, where u71xx is the Predator hardware model number for your vehicle, which for an '06 GTO is U7191?).
2010 Camaro SS M6
have we figured out what's wrong with the "bc" version and why it says it's not a trinity file?
bc is just a bad file.orspg wrote:have we figured out what's wrong with the "bc" version and why it says it's not a trinity file?
