Page 2 of 2
RE: New trinity incremental with added calid support..
Posted: Sun Jun 06, 2010 3:31 pm
gotta data log you can post up???
Posted: Sun Jun 06, 2010 4:41 pm
by orspg
sure, what do you want to see? I got the regular stock, tuned +4 and two WOT's runs. Thanks for checking them out for me, Lew!
Posted: Sun Jun 06, 2010 5:00 pm
go to modify tune... go to spark advance, and set the upper rpm range to -3...
Posted: Sun Jun 06, 2010 10:47 pm
by orspg
Which range? It gives me three choices. I set the lowest to -5 and next two to -3, previously. What should I do and thanks for checking out the numbers! How did they look to you? Really? I took out the Jet MAS as you recommended on all the runs.
Posted: Mon Jun 07, 2010 6:28 am
like I said... the upper rpm range... which is the highest rpm range....
Posted: Mon Jun 07, 2010 7:42 am
by orspg
K, thanks, I'll set the other two to normal.
Re: RE: New trinity incremental with added calid support..
Posted: Tue Jun 08, 2010 9:31 am
by Fordlitenin
06MonteSS wrote:Fordlitenin wrote:Since I am not a Trinity programer what is the latest crom update for the Trinity product? U7194, U7163 not sure. Is there not some kind of revision control on this?
huh???
if you have a ford, then you're in the wrong place... heh... and a 7194 update is not for you, that's for GM vehicles...
do you mean a U7136?? cuz there is no 7163....
latest trinity updates are the main update to 1r07... then the incremental update to trinity_u7136-1r07a_update.crom
Review previous questions and you would know that I also own a 2006 GTO which I have been trying several times to determine the latest update for the Trinity that I have. The one provided as the latest doesn't have all the backgrounds for the gauges(wallpaper). Since I don't know the differences between U7194, U7136, etc that you all use.
RE: Re: RE: New trinity incremental with added calid support
Posted: Tue Jun 08, 2010 3:01 pm
k... for the 06 gto... the trinity latest revision you need is the trinity_u7194-1r07a_update.crom...
Posted: Tue Jun 08, 2010 3:34 pm
by tmizer
Yeah, I believe you need 2 files: latest "Trinity Crom", and then the appropriate incremental update crom (u71xx, where u71xx is the Predator hardware model number for your vehicle, which for an '06 GTO is U7191?).
Posted: Thu Jun 10, 2010 8:23 am
by orspg
have we figured out what's wrong with the "bc" version and why it says it's not a trinity file?
Posted: Thu Jun 10, 2010 10:01 am
orspg wrote:have we figured out what's wrong with the "bc" version and why it says it's not a trinity file?
bc is just a bad file.
