Page 2 of 5
Posted: Sat Mar 13, 2010 10:50 am
by PaCharger_
My Trinity is on the dash, by the pillar, cables routed down the door jamb (behind plastic), neatly coiled and plugged into ODBII directly above gas/brake pedals.
Posted: Sat Mar 13, 2010 12:00 pm
do not wedge/jam/pinch the cables between anything...
if you pinch the cable, there can be issues... had it with mine...
I wedged/jammed the cable between my a-pillar and side of my dash, and then when I went to use the trinity and was driving, all of my dash lights, DIC, etc etc started going all whacky, giving me message on my DIC, guages/lights flipping out...
as soon as I un-wedged/un-pinched the cable, everything worked fine again...
Posted: Sat Mar 13, 2010 2:41 pm
by PaCharger_
06MonteSS wrote:do not wedge/jam/pinch the cables between anything...
Too late...just happened to me, lmao
Just came inside and ordered the 90* cable.....guess i needed it anyway...now to go back and unpinch the dang cable, ugh...
Posted: Sat Mar 13, 2010 2:42 pm
by gizmodo
It has nothing to do with where the cables are run, or what type they are. I have tried a lot of different configurations, and it happened with both my beta and production units. It is a problem with the Trinity itself.
Posted: Sat Mar 13, 2010 2:58 pm
by PaCharger_
Well, nothing pinched...just have a gremlin now.
between afr being jumpy, key fob issues, now this..hmmmm...
http://www.youtube.com/user/PaCharger1967?feature=mhw4
Posted: Sun Mar 14, 2010 10:57 pm
by cfvzw
I agree, I appreciate all the help but $600.00 to randomly turn on & off features of my vehicle is not what I paid for when I purchased the unit regardless of cable configuration or where the Trinity is mounted. Frankly, it's unexceptable. I basically bought a very expensive predator. It just would have been nice to know before hand. At the very least someone from Diablo Sport could have responded to this thread.
Posted: Mon Mar 15, 2010 12:04 pm
by gizmodo
bump...
Posted: Mon Mar 15, 2010 4:55 pm
by cfvzw
OK, trying really hard not place any undue blame on the Trinity but today I took a call via Uconnect w/o the Trinity plugged in and had no problems. Later, figured I plug the Trinity in just for fun and when I recieved another phone call Uconnect did not pick up the call.
Posted: Fri Apr 09, 2010 5:58 am
by cfvzw
Hello, ..., can you hear me now?
Posted: Mon Apr 12, 2010 3:40 am
by cfvzw
Well, now using the Trinity as a Predator and the Dashawk for display. Very disappointing!
Posted: Mon Apr 12, 2010 3:42 am
by cfvzw
" Posted: Mar 11, 2010 - 05:32 PM "
Posted: Tue May 11, 2010 3:38 pm
by pjtem
Same problem here, when plugged in, no GPS reception and keyless features only work about 3 feet away. Unplugged, everything works fine.
Posted: Wed May 12, 2010 10:00 am
by Stone2500
I have an 05 GTO. I had the same issue. It was very frustrating. I thought the battery in the FOB was dead and changed the battery. That did nothing. So here is what I did. I Put the wire up under the dash and have my trinity with about a 2 inch lead coming out of the dash and I tinted my windows. By putting it right behind the pillar next to the drivers window and stashing the cord in the dash, I was able to reduce the interference enough that MY FOB will work from about 20-50 feet now. Better than 4 feet and hitting it multiple times like I had to do in the past. Hope this helps!!!!
Posted: Thu May 13, 2010 4:51 pm
by duster360
I'm pretty sure its the OBD cable more than the trinity.
A simple test would be to power the Trinity with the USB and see if the emi performance changes.
My fob isn't programmed to my new PCM or I'd test it myself.
Posted: Thu May 13, 2010 5:33 pm
by Mike_Levy
Won't have any effect if its not plugged into the car. I've run it in the car with PC power and everything works fine.
