No, I'm still not satisfied with any one setting I could be comfortable racing with. I need to get the fueling dialed in. I can still run the rail dry in some settings.mikel wrote:You had that thing to the track in its 547 rwhp state?
predator//power puck question
Re: RE: Re: RE: Re: RE: Re: RE: predator//power puck questio
03'/305 Dually 4 x 4
Platinum FASS/150,/Level II CP3, 60hp.Inj.
Stage 1 cold air box, BD Intercooler
Smarty SSR,62/65/13ss, CFM+
Goerend Trans. Westach, Fuel/Rail Gauges
2011 Laramie Longhorn All Stock
07BigHornRam
RE: Re: RE: Re: RE: Re: RE: Re: RE: predator//power puck que
ropnjessi did that input shaft break with stock tranny or Goerend tranny?
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: predator//power puck
That was an all stock tranny, it broke clean off with no debris. There were other signs of he tranny going, so there might have been something else on the way out as well.07BigHornRam wrote:ropnjessi did that input shaft break with stock tranny or Goerend tranny?
07BigHornRam
Re: RE: Re: RE: Re: RE: predator//power puck question
I would have to say yes it can handle it, I recall hitting 27000 before. Maybe an 07 can handle it better then an 03. But if you add anything else that involves fuel pressure I believe the rail will begin to fall off. Even when I ran the Arson III, and turning up the TST I could run out of fuel.07BigHornRam wrote:ropnjessi thats seems like alot. can the stock setup handle that?
