ltft's seem too excessive
on injector slope... going positive makes it leaner.. makes it spray less fuel...
going negative on injector slope, makes it richer, makes it spray more fuel...
for the WOT/PE fueling, going positive makes it richer, makes it add more fuel for WOT/PE...
going negative on WOT/PE fueling makes it leaner, makes it subtract fuel for WOT/PE...
rjaro7
Post by rjaro7 »
is this predator ok to use on a flex fuel..if so can i just switch to e85 or do i have to go back to the stock tune instead of the 87oct
2010 GMC Sierra 5.3 Flex
if you're going to use E85 all the time, I would contact Andrew at dynotuneusa.com for a custom tune for it, since the regular diablo tunes are not specifically made for E85 fuel...
Andrew's the E85 tune guru... [email protected]
