High Flo Cat Back System Causing Engine Light Code - HELP!
RE: Re: RE: Re: RE: High Flo Cat Back System Causing Engine
i thank mike for rear sensor fix. what about the front ones? my dealer tells me both sets are tripping codes.
The fronts shouldn't be throwing codes. If they are then theres a problem with them. Check the wiring and make sure its not melting on anything, and if thats okay, change them out. I just picked up a pair at AutoZone last week for $24 each.
thanks...will let you know the outcome
mike, by the way, sensors on headers are new. replaced when installed . spoke with slp rep, and he swears no way to pass inspection due to the longtubes.
Use the non-foulers. You'll get through inspection. I have Stainless Works headers and with the non-foulers in place they pass the shitty NY inspection, which is among the worst (along with CA, MA, CT, ME).
