Idle
Re: RE: Re: RE: Idle
Spinmaster wrote:Same issue. The idle bounces down then up. I too found that by turning on the AC the idle will increase.
I have tried numerous idle settings / rpm adjustments and found no difference.
The car does it with or without a tune. "No cam"
09 R/T auto
Mopar CAI
AIRAID throttle body spacer
180 stat
Corsa exhaust
catch can
Yours is the TB Spacer. Pull that POS off. What is the purpose of using a PLASTIC spacer to isolate the TB from a PLASTIC manifold? All it does is make a whistle and make tuning more difficult.
Use it as a door stop. Thats all its good for.
Spinmaster
RE: Re: RE: Re: RE: Idle
Post by Spinmaster »
Great response! It was on the car when I bought it. The issue is present with or without it.
Let’s get back to the issue at hand. Seems to me quite a few folks out there have the issue and it would seem you can not adjust/increase a fixed idle using the tool.
Excuse me for helping. Only been working with Hemis for the past 5 years and seen the stupid spacers cause more problems then they're worth.
