Logging real-time data
corny40
RE: Re: RE: Re: RE: Logging real-time data
Post by corny40 »
Okay, Thanks! :D
Yes Corny/JohnC... my Predator on-screen vehicle speed shows Km/H as well... but logs show mph...
johnc
Post by johnc »
This has been fixed in the latest DataViewer release, which I will post before I leave for the day. It should be corrected (on screen and in the exports) for your two vehicles by default, with a user setting to invert it for those users with older cars.
johnc <at> diablosport.com
Dataviewer fix/release isn't gonna fix the Predator screen display though... that's what's showing the km/h speed...
The dataviewer stuff is fine... it's the actual Predator that's showing km/h on its screen...
same with the AFR... the Predator shows my AFR up at 17+ on its screen, but it is correct in the logs/dataviewer...
johnc
Post by johnc »
(If I recall correctly) you guys were using the 3.0 data viewer because of the AFR inversion on the display and in the CSV export. You can now use the 3.1 viewer.
As for the Predator changes, somebody else has ownership of that issue.
right... but that's the issue...
the AFR on the Predator screen shows (in my case) 17+ at WOT... but the dataviewer/logs show the correct AFR value.
The vehicle speed on the Predator screen shows km/h, but the dataviewer/log shows the correct mph value.
the 3.1 dataviewer data and exported csv logs was a different issue...
