Ahem...OK...TCM support anyone???
bulletpryor86
Post by bulletpryor86 »
[email protected] send me a test crom please
bulletpryor86
11z71
tcm file
Post by 11z71 »
Mike here is that tcm file
TCM_256125258793.grg
(956.32 KiB) Downloaded 280 times
(956.32 KiB) Downloaded 250 times
RE: tcm file
email sent, thanks for the backup file.
Re: tcm file
11z71 wrote:Mike here is that tcm file
On your trinity, if you go to options/show information, what is the version shown there?
RE: Re: tcm file
something is not adding up.
1. Johan tells me that your TCM cal is supported in the 1r08gc crom, which I check and is what I sent you.
2. The file you sent says it was exported from 1r08gb, which I never sent you?
11z71
RE: Re: tcm file
Post by 11z71 »
Mike, it shows version v.1t08gc.
RE: Re: tcm file
weird, looking into this...
11z71
RE: Re: tcm file
Post by 11z71 »
Also my gauges in the monitoring portion of my trinity are gone and if I try to send the original tcm back up to the trinity ,dsdownloader shuts off or won't respond. I even tried uninstalling and installing the software numerous times.
RE: Re: tcm file
go to options/change vehicle type and reselect your vehicle again, see if the dashes reappear.
You wont be able to reload an unsupported tcm file back to the trinity, nor do I understand why you would want to?
Re: RE: Re: tcm file
11z71 wrote:Also my gauges in the monitoring portion of my trinity are gone and if I try to send the original tcm back up to the trinity ,dsdownloader shuts off or won't respond. I even tried uninstalling and installing the software numerous times.
OK, your tunes are added, new revision in your email ;)
11z71
RE: Re: RE: Re: tcm file
Post by 11z71 »
Ok thanks. I'll give it a whirl.
11z71
Post by 11z71 »
Still says unsupported. It read both pcm and tcm ,backed up both, but only allowed me to tune pcm. Plus my gauges still won't come up. It asks if I want to restore back to default layouts I select yes and still nothing.
you have a 6-speed transmission, right??
11z71
Post by 11z71 »
Yes it's a 6l80e. I may have been wrong here aswell. I went back in to my truck after my last post, If i went into the tune menu of the trinity and selected the diablo tune, go into modify the diablo tune, it will show the option to modify either engine or transmission, If I select a tranny parameter to modify it tells me my tranny's unsupported and to call such and such a number and so on. But then it will revert back to that particular parameter and let me make a change. I haven't gone any further than that. Also My other question is will you guys add the ability to change wot throttle upshift points? and possibly tcm removal from the tranny side? thanks
Return to “Trinity GM Gas”
