Page 2 of 14
Posted: Thu Oct 13, 2011 7:45 pm
by bulletpryor86
[email protected] send me a test crom please
Posted: Thu Oct 13, 2011 9:28 pm
by bulletpryor86
tcm file
Posted: Fri Oct 14, 2011 8:28 am
by 11z71
Mike here is that tcm file
RE: tcm file
Posted: Fri Oct 14, 2011 8:49 am
email sent, thanks for the backup file.
Re: tcm file
Posted: Fri Oct 14, 2011 9:54 am
11z71 wrote:Mike here is that tcm file
On your trinity, if you go to options/show information, what is the version shown there?
RE: Re: tcm file
Posted: Fri Oct 14, 2011 9:59 am
something is not adding up.
1. Johan tells me that your TCM cal is supported in the 1r08gc crom, which I check and is what I sent you.
2. The file you sent says it was exported from 1r08gb, which I never sent you?
RE: Re: tcm file
Posted: Fri Oct 14, 2011 11:03 am
by 11z71
Mike, it shows version v.1t08gc.
RE: Re: tcm file
Posted: Fri Oct 14, 2011 11:08 am
weird, looking into this...
RE: Re: tcm file
Posted: Fri Oct 14, 2011 11:29 am
by 11z71
Also my gauges in the monitoring portion of my trinity are gone and if I try to send the original tcm back up to the trinity ,dsdownloader shuts off or won't respond. I even tried uninstalling and installing the software numerous times.
RE: Re: tcm file
Posted: Fri Oct 14, 2011 11:53 am
go to options/change vehicle type and reselect your vehicle again, see if the dashes reappear.
You wont be able to reload an unsupported tcm file back to the trinity, nor do I understand why you would want to?
Re: RE: Re: tcm file
Posted: Fri Oct 14, 2011 4:52 pm
11z71 wrote:Also my gauges in the monitoring portion of my trinity are gone and if I try to send the original tcm back up to the trinity ,dsdownloader shuts off or won't respond. I even tried uninstalling and installing the software numerous times.
OK, your tunes are added, new revision in your email ;)
RE: Re: RE: Re: tcm file
Posted: Fri Oct 14, 2011 4:57 pm
by 11z71
Ok thanks. I'll give it a whirl.
Posted: Fri Oct 14, 2011 6:10 pm
by 11z71
Still says unsupported. It read both pcm and tcm ,backed up both, but only allowed me to tune pcm. Plus my gauges still won't come up. It asks if I want to restore back to default layouts I select yes and still nothing.
Posted: Sat Oct 15, 2011 12:08 am
you have a 6-speed transmission, right??
Posted: Sat Oct 15, 2011 8:10 am
by 11z71
Yes it's a 6l80e. I may have been wrong here aswell. I went back in to my truck after my last post, If i went into the tune menu of the trinity and selected the diablo tune, go into modify the diablo tune, it will show the option to modify either engine or transmission, If I select a tranny parameter to modify it tells me my tranny's unsupported and to call such and such a number and so on. But then it will revert back to that particular parameter and let me make a change. I haven't gone any further than that. Also My other question is will you guys add the ability to change wot throttle upshift points? and possibly tcm removal from the tranny side? thanks
