2011 silverado e85?
mxer97
RE: Re: RE: 2011 silverado e85?
Post by mxer97 »
Off topic mikel, but I am trying to adjust the axle ratio on this u7194 and the base for the adjustment says 3.22 and the high is 6 and the low is 0 ..... Where is 4.10 at on that spectrum ? Thanks
it wont let you make fine adjustments?
try updating to this
u7194-9t27b.crom
(1.59 MiB) Downloaded 186 times
rjaro7
Post by rjaro7 »
I have a 2010 sierra with a 5.3 flex fuel. I used the diablo tune when I was using e85. It was the fastest the truck has ever ran with no knock retard. I went from 16 mpg with 87 octane gas with the 87 octane tune to 11 mpg using e85 with the diablotune.
2010 GMC Sierra 5.3 Flex
e85 FTW!
rlkimmel
E85
Post by rlkimmel »
My 2010 Colorado 5.3L is flex fuel. Although I've never used it, I understand my truck would run like the proverbiale "Bat out of hell. " In all cases the milage would drop by 30 to 35% and I've heard stories about burned valves and a host of other problems with running it full time. For one thing, ethanol burns a lot faster than gasoline so the timing has to be retarded a lot and the computer won't self-adjust that much if you run gas. As far as gas goes, the higher the octane the slower (and smoother) it burns. Several racing organizations have "gone green" but bear in mind that those engines are built to last about 1,000 miles or less. The only way I'll ever use ethanol is if gas isn't available.
mxer97
RE: E85
Post by mxer97 »
How do I go about doing that mikel ?
mxer97
RE: E85
Post by mxer97 »
Never mind lol!!! I asked that while I was half asleep lol
mxer97
RE: E85
Post by mxer97 »
Still didn't work mikel ... I'm not sure what the deal is its doin the same thing as last time its just my shift points are a little lower lol
RE: E85
post your backup and last tune written and ill do it for you.
mxer97
RE: E85
Post by mxer97 »
Hey mikel ! I'm gonna put that tune up here tonight how soon could u have it... My truck only makes the shift rpm adjustments I made when I walk it through the gears ... Not in drive... And I also need it set to 4.11 gears thanks ... Anywhere specifically u want me to send that tune too ?
RE: E85
just post it here...
RE: E85
post it up here in this thread...
mxer97
RE: E85
Post by mxer97 »
I'll post it up about 6:15 central time
mxer97
Post by mxer97 »
original
original backup tune.grg
(64.21 KiB) Downloaded 192 times
PCM_639835640536_Diablo_Tune_modified.grg
(1.25 KiB) Downloaded 198 times
