DSLogRedux HELP
Ill_Born_SS
Post by Ill_Born_SS »
Lets start over here.... What car? What Predator and version #?
" Just Friggin Wicked"
Now with TCM support...
XxScottxXN
Post by XxScottxXN »
My car is an 06 Monte SS...U7191...version v.9r03????
2014 Camaro SS/RS 1LE, CAI intake, Stainless Power LT headers, Bo White ported/polished TB, and a Badass tune from LEW!!!
Ill_Born_SS
Ok, open DataViewer and click on the help tab and then click on about DataViewer, what version does it say?
What version of Windows do you have ? Do you know if it is 32 bit or 64bit ? Do you have Office installed ? What version?
XxScottxXN
OK....I have the dataviewer # 3.3.0.8, windows 7 64bit, and I have microsoft office starter 2010 in my list of programs. Am I doing good so far?? :)
XxScottxXN
This is the details to the error code I'm getting on my computer and have no clue what any of it means!!!!
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UnauthorizedAccessException: Access to the path 'C:\Program Files (x86)\FGBSoftware\DSLogRedux\Raw_Data210022268.csv' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options)
at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize)
at System.IO.StreamWriter..ctor(String path, Boolean append)
at System.IO.File.CreateText(String path)
at DiabloLog.frmMain.Button2_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.5448 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
DSLogRedux
Assembly Version: 6.3.1.0
Win32 Version: 6.3.1.0
CodeBase: file:///C:/Program%20Files%20(x86)/FGBSoftware/DSLogRedux/DSLogRedux.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
Win32 Version: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
Win32 Version: 2.0.50727.5447 (Win7SP1GDR.050727-5400)
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
Win32 Version: 2.0.50727.5420 (Win7SP1.050727-5400)
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
Accessibility
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/windows/assembly/GAC_MSIL/Accessibility/2.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
System.Xml
CodeBase: file:///C:/windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
"Access to the path 'C:\Program Files (x86)\FGBSoftware\DSLogRedux\Raw_Data210022268.csv' is denied. "
you don't have permissions set correctly on your PC....
you need to turn of the UAC on Windows7... UAC is the User Access Control...
check the FAQs and Installation sections on the dslogredux forums for info:
http://dslrforum.dslogredux.com/
XxScottxXN
I changed some user account thing and it still didn't work
Ill_Born_SS
When you installed your software for your diablosport ... right from the beginning, did you just install it or did you install it using
" RUN AS AN ADMINISTRATOR"
-if you just installed it, remove it all and then restart your computer
-then either re download the programs to your desktop or go to the downloads section of your computer. Then right click each program as you wish to install and select from the popup window "RUN as ADMINISTRATOR" this will give the program admin rights and the permissions you are looking for.
read ALL the FAQs and Installation sections on the dslogredux forums for info:
your issue can/will be resolved if you follow all the info/instructions in those threads... this is an issue with your PC setup, not a software issue... you need to get things setup correctly on your PC...
XxScottxXN
Woohooo!! I got the logredux to work..... BUT... The recommended injector slope was -8 and I read in some of Lews posts that it is too much for the Monte!! Is there any way to adjust somewhere else? And what % needs to be logged on WOT in order to get a good log?
And Thank you "Ill BORN SS" and "06MonteSS" for the help and being patient with me. Now I have alot of tune questions lol ...Sorry!! :)
Scott
nice!!! woohoo!!! hahaha...
no, nowhere else to adjust for that.. need a custom tune to have the MAF sensor table adjusted instead...
also, you have any mods like CAI, exhaust? check them, make sure all clamps/bolts are TIGHT so that there are no air leaks anywhere... an air leak can/will cause high LTFT's like you're getting...
XxScottxXN
Thanks, I'll check for leaks!! I don't have any mods, the predator is my first mod but would like cold air box and a different exhaust!! And I'll have to wait for a custom tune....when I win the lottery...or the boss gives me more money, and by "boss" ..I mean "work boss" AND "home boss". Do you ever have a special on those cool tunes or same price always??
$135 is pretty much it really... since i'm already lower than others... is it out of the question? no... but not usually... too many damn bills to pay lol
XxScottxXN
I would really like to see what your tune does to my car so I'll have to save my pennies and try and have you do it and hopefully it happens before I wind up trading it off. It only has 40,000 miles on it so I'm thinking about keeping it!! But I really want a newer Camaro. lol
