Help with throttle boost
white_lightning
Re: RE: Re: RE: Re: Help with throttle boost
Post by white_lightning »
Mike_Levy wrote:
white_lightning wrote:
Mike_Levy wrote:Real easy. I made one the other night in about 3 minutes out of scrap parts. Used crimp connectors since thats what I had around. No idea if I'll ever use it, or if I need it, but I had nothing better to do.
you have an SRT-8, right? may not get the same improvement, since 6.1 intake is aluminum and conducts electricity. should have much better direct ground than plastic 5.7 intake.
I have a CTS-V. The ground is through the supercharger. I didn't actually make it to use, just made it because I had nothing else to do, and my hands have to be doing something or I starting picking on paint and stuff like that. :oops:
LOL!
picking paint will actually give you something to do always. you pick the paint off, then you re-paint where you picked the paint off. repeat over and over and over! :twisted:
dficarra
RE: Re: RE: Re: RE: Re: Help with throttle boost
Post by dficarra »
Good news, I made that ground cable and hooked it up yesterday. Worked like a charm! All these years living with that stupid delay and now it responds the way it should. Thanks for the info guys! Much appreciated.
I do have a questions about the throttle boost adjustment on the predator, if I'm using the regular 91 oct CAI tune, can I also adjust the throttle boost? Or is that something that's only available if you're doing a custom tune mod?
white_lightning
you're welcome for the info!
you can adjust throttle boost +/- 20% on both canned tunes and custom tunes with your tuner.
Diablo Dodge CMR Tuner
Cell Phone#: (520) 508-5320
My Ride:
2005 Ram QC 1500, APS converter, 210/214 112 LSA cam, LT headers, True Duals, 4.56 gears, 180* T-Stat and some other mods. Tuned by Me.
beam3215
Post by beam3215 »
Wow!! I gotta try this as well....thanks guys......
'13 R/T Charger w/ STP: DS catch can / Mopar CAI / SRT headers & mid pipes
beam3215
Post by beam3215 »
Did this tonite before I went to work........What a difference!!! Right from my driveway, it was noticeable. Can't believe this simple "mod" did what it did. No more lag...instant accelleration. Thanks White Lighting!!
white_lightning
Re: RE: Re: RE: Re: RE: Re: Help with throttle boost
beam3215 wrote:Did this tonite before I went to work........What a difference!!! Right from my driveway, it was noticeable. Can't believe this simple "mod" did what it did. No more lag...instant accelleration. Thanks White Lighting!!
you're welcome beam3215!
My Ride:
kmartin100
Post by kmartin100 »
I have 2011 Dodge Ram with the 5.7, Will that grounding thing help my year of truck.
white_lightning
kmartin100 wrote:I have 2011 Dodge Ram with the 5.7, Will that grounding thing help my year of truck.
not sure. is the 2011 intake plastic or metal?
if you have an ohm meter, you can check if TB is grounded. put one lead on the throttle body, and the other lead on valve cover, ground bolt on side of engine bay, (-) battey cable or other ground and you can see if there is some ground, no ground or good ground.
My Ride:
kmartin100
RE: Re: RE: Re: RE: Re: RE: Re: Help with throttle boost
I will have to check, the TB faces up so I'm not sure if it is metal or not. Thanks for getting back with me''
white_lightning
Re: RE: Re: RE: Re: RE: Re: RE: Re: Help with throttle boost
kmartin100 wrote:I will have to check, the TB faces up so I'm not sure if it is metal or not. Thanks for getting back with me''
you're welcome.
throttle body should be metal. aluminum, I think.
intake manifold is plastic on 03- 08 Hemi Rams, so ground is poor to none.
I don't know what the intake manifold is made of on a 2011 Ram 5.7.
My Ride:
kmartin100
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: Help with throttle b
That TB aluminum and I already did the ground wire, I seems to work but I will have to drive it more.
typan
Post by typan »
Sorry guys but I cannot see how a ground wire would work as the TB housing has NO electrical connection from any of its components within. We have an old faulty TB and I will be opening it up for a look inside.
kmartin100
I see what everyone is saying about the grounding of the TB, most electronics have a ground wire in the harness, but it will try to ground itself through the item the harness is hooked to. I'll have to test it more to see if it is working.
Does anyone have some more performance tricks like the grounding of the TB. Sense a tuner is not out yet.
white_lightning
there is one way to tune a 2011 Ram:
replace 2011 PCM with 2010 PCM. read a thread about it on another forum.
My Ride:
kmartin100
Sorry, I cant open the tread. I dont know about changing the PCM, How much do the cost?
