Well, I have went the so called better fuel route. That has not panned out. I will have the intake pvc checked out. In the mean time, what if any kind of adjustments can I make to the tune either Diablo, or 91 tune to help alleviate the problem?mikel wrote:No, Im just suggesting that you'll likely see a bit of knock with the stock tune, indicating you need either better fuel, or perhaps have oil contamination in thee intake/pcv.
Latest Intune release here.
Re: RE: Re: RE: Re: RE: Re: RE: additional DBS for VIn etc
When I try to drag-and-drop the updates from my Mac, my inTune also gives the message "This inTune cannot be updated until it is Registered". I don't have a PC, so I can't register using the EXE file on the inTune... is there another way to register from the device so I can make the updates using my Mac?JonDiablosport wrote:for the intune you have to register from the device.
post or email me the info.xml file please.gargabot wrote:When I try to drag-and-drop the updates from my Mac, my inTune also gives the message "This inTune cannot be updated until it is Registered". I don't have a PC, so I can't register using the EXE file on the inTune... is there another way to register from the device so I can make the updates using my Mac?JonDiablosport wrote:for the intune you have to register from the device.
the auto updater will do it for you...achavez71 wrote:Hey I was just wondering if I i still have to wait for an update for the intune to work on my 11 mustang gt
Same issue here....mikel wrote:post or email me the info.xml file please.gargabot wrote:When I try to drag-and-drop the updates from my Mac, my inTune also gives the message "This inTune cannot be updated until it is Registered". I don't have a PC, so I can't register using the EXE file on the inTune... is there another way to register from the device so I can make the updates using my Mac?JonDiablosport wrote:for the intune you have to register from the device.
Here's my XML
drag/drop this file to the tool, then you can finish loading the updates.BRR wrote:Same issue here....mikel wrote:post or email me the info.xml file please.gargabot wrote: When I try to drag-and-drop the updates from my Mac, my inTune also gives the message "This inTune cannot be updated until it is Registered". I don't have a PC, so I can't register using the EXE file on the inTune... is there another way to register from the device so I can make the updates using my Mac?
Here's my XML
that did it, it downloaded all updsates even the missing files I had...thanks again!
awesome, enjoy.
Can you condense the updates to one post? I'm about lost on what needs to be updated and what is an old update. My tuner is all jacked up with updates now and says my pcm calibration is not supported.
how do you register the inTune from the device itself?
info.xml
info.xml
when you allow the intune.exe updater software to run, it will prompt you to register.
I have a MAC so I cant run the updater software
drag/drop the attached file to the intune drive of the tool, and it will be registeredhendy16 wrote:I have a MAC so I cant run the updater software
RE: Re: RE: Re: RE: Re: RE: Re: RE: additional DBS for VIn e
worked great thanks!
