thanks. i will do a datalog tomorrow and see what shows upmikel wrote:They will show up in DV, we have not yet added the ability to see them in the tool.
how to datalog wideband AFRs
UnseenByYou
Re: RE: how to datalog wideband AFRs
UnseenByYou
RE: Re: RE: Re: RE: how to datalog wideband AFRs
did a log and it still hasnt showin up. im 99% sure i wired everything up correctly
On DV try File->Re Query Vehicle info while InTune attached to both PCM and PC/Laptop. May need to "double-click" the EXTERNAL sub tree in DV. Verify your using most current version of DV too.
I am wondering if I wired up my plug correctly because I am not seeing the wideband input anywhere. I am also unsure as to what channel to assign it.
I have checked the plug and the voltage is at the tip. Dunno if it reads at the tip or the ring.
The inTune has two analog input channels. One for the tip and one for the shaft.
UnseenByYou
ima just switch input channels til somethin shows up lol
