NEED TUNING for my c6 PLZ
Tune sent via email.
zo6112
Post by zo6112 »
Hi Mikel
i recieved your tune via email, but while downloading the tune to the predator I got this error message: file formatting not recognized.
let me know plz.
thanks in advance.
Make sure the compressed send button is checked on the DSDL.
zo6112
Post by zo6112 »
Ok, try unchecking it.
shouldn't you be using the GMLS2InterfaceInstaller to import/export the tunes?? that's the one that I always use...
I only use the DSDownloader for updating the predator crom files...
DOH!!!
Lewis, what the hell would I do without you?
Talk about a brain fart.....
MonteSS is correct, you need to use the LS2 interface to load the tune to the Predator.
zo6112
Post by zo6112 »
mikel wrote:Ok, try unchecking it.
OK 8) I unchecked it & voala it worked.Thanks Mike :D
zo6112
Post by zo6112 »
Mike
I installed the costum tune on the car & here are the reading:
1- on 60 mph, both long trims are + 4.75
2- on idle, both short trims are + 3.45 and its not stable.
3- random misfiring code
4- rough idle
5- while cruising i put on nutral gear the rpm stays on 2000 rpm & gos back to normal when stopping.
6- o2 wide band is lean 1.5 and this is the avrage. and we tried to increase more fuel, but still is 1.5 lean.
Abdulla
got a log file you can post??
zo6112
Post by zo6112 »
log file is attached and i dont know if i did it right :roll:
and i got 3 codes:
1- p0106
2- p0300
3- p0507
*o2 wide band is lean 1.5 and this is the avrage.
*rough idle.
*while cruising i put on nutral gear the rpm stays on 2000 rpm & gos back to normal when stopping.
thanks in advance
c6 G5X3.zip
(217.79 KiB) Downloaded 241 times
need to get those codes/items checked out before tuning anything..
the P0106 is a MAP sensor problem:
http://www.gearchatter.com/viewtopic9390.php
P0300 is your misfire - emissions type or catalyst-damaging misfire:
http://www.gearchatter.com/viewtopic9365.php
P0500 is your engine/idle speed: - actual engine speed is 200 rpm more than the desired engine speed for more than 8 seconds:
http://www.gearchatter.com/viewtopic9344.php
....now you see why we dont like to do head/cam tuning via email....
I need you to resend me the backup file and the tune we made and we'll give it another shot.
zo6112
Post by zo6112 »
attached.
thanks.
1g1yy24u955130687.zip
backup file.
(81.67 KiB) Downloaded 274 times
1g1yy24u955130687_toon.zip
tune file
(80.36 KiB) Downloaded 201 times
Ok, I just emailed you a new tune.
