2009 Dodge won't tune i 1000
iancampbell
RE: Re: RE: Re: RE: 2009 Dodge won
Im having the same problem also!!!!! Hope they fix it soon!! It sucks having a $400 paper weight!!!!
I just posted in another thread then found this one so I am going to post the same info here as you requested from a previous user.
i1000
1r01h
2009 Dodge Charger
Here is the file requested above;
<?xml version="1.0"?>
-<tool_info> <main svn="4210" sw_rev="1r01h" full_version="InTune-1r01h 03/29/2012 12:07:10 PM"/> <registration status="1" sn="CIAPRAF-1"/> <restore bc="0" vin="2B3LA53T89H503430" id="0"/> <db pid="1r01a" tune="1r01d" mfr="GM"/> <db pid="1r01a" tune="1r01a" mfr="DCX"/> <db pid="1r01a" tune="1r01a" mfr="FORD"/> <system_db vin="1r01a" info="1r01a" dtc="1r01a"/> <license tuned="0" avail="1"/> <updates count="1"/> </tool_info>
If there is no fix let me know so I can return it as I just bought it today.
i1000
1r01h
2009 Dodge Charger
Predator model U7191 (06 GTO)
iNTune i1000 (08 Z-71 LTZ)
2008 Z-71
03 Polaris SP 600
2008 Z-71
03 Polaris SP 600
can you plug it into the truck, get it to ask you to do a cal update again, then post the info.xml file here, so i can make the update file for you?
Note this is a 2009 Dodge Charger, not a truck, if it makes a diffrence.
- <tool_info>
<main full_version="InTune-1r01h 03/29/2012 12:07:10 PM" sw_rev="1r01h" svn="4210" />
<registration sn="CIAPRAF-1" status="1" />
<restore id="0" vin="2B3LA53T89H503430" bc="0" />
<db mfr="GM" tune="1r01d" pid="1r01a" />
<db mfr="DCX" tune="1r01a" pid="1r01a" />
<db mfr="FORD" tune="1r01a" pid="1r01a" />
<system_db dtc="1r01a" vin="1r01a" info="1r01a" />
<license avail="1" tuned="0" />
<unsupported calid="05187905AE" vin="2B3LA53T89H503430" oem="DCX" />
<updates count="3" />
</tool_info>
- <tool_info>
</tool_info>
2008 Z-71
03 Polaris SP 600
2008 Z-71
03 Polaris SP 600
I need the actual file please...
drag/drop the attached file to the intune drive, and it will import it and reboot, this is the cal update file.WTO wrote:See attached, sorry...
Once it is loaded, take it to the car and load the update to the vehicle, then you can tune it.
like log playback, etc?
If so, yes, they are all coming
mine still doesn't work
- <tool_info>
<registration sn="CIBW441-1" status="1" />
<restore id="0" vin="1D3HV13T59J520130" bc="2" />
</tool_info>
- <tool_info>
</tool_info>
09 Dodge Ram Hemi Ram box Rocks
11 blackberry Durango awsome collor
I'll email you the update in the morning.RLROACH wrote:mine still doesn't work
- <tool_info>
</tool_info>
update has been released for anyone running into this.
no, 1r01i is the latest, and it is the fix.
