2005 Chevrolet Avalanche
Viciouslifter
Post by Viciouslifter »
It says i need a .cvs file, can you convert it?
I figured out how to convert it. But it says the AFR is not represented in the log file am i logging with a U7198, U7195, U7193, or U7192? Select Yes or No
Select Yes. The Avalanche uses a U7193.
Viciouslifter
It's saying i need the "Command Throttle Position or the Absolute Throttle Position it's not represented in the file.
Which Dashboard are you using to log? Theres one just for DSLogRedux that has all the required info in it.
Viciouslifter
Where do I find that logger at?
Its on your Trinity. Instead of making yourt own, you should be able to open it up.
Viciouslifter
Mike_Levy wrote:Its on your Trinity. Instead of making your own, you should be able to open it up.
Where is it located at?
When you go to Logging, it should come up Choose a Gauge Layout. The top one says DS_LOG_REDUX. Select it.
Viciouslifter
I don't have that option on mine all i have is GM_GAS, also how do i log the catalyst temperature.
Viciouslifter
I made my own logger for redux I've done a little tuning and have noticed a huge difference so far! I'm loving this thing!
Viciouslifter
After two hours of logging and adjustments i've got my truck getting about 26-28 mpg highway and it has more power then i ever thought possible! My only addons for a stock 2005 Avalanche 5.3 Vortec V8 is the AFE Power Stage 2 cold air intake and a magnaflow 12579 muffler with stock cats/pipes. And of course the Diablosport Trinity tune, tuned by yours truly using diablotune as a base and adjusting with DSLogRedux! Thank You so much for your help! It's very appreciated :)
awesome.
Nce!! ;)
Viciouslifter
I've only been given two parameters to tweak, are there helpful tools for adjusting parameters other then slope and wot?
Thats all you can do without the CMR software. CMR is for pro's only. Or wannabe pro's who can drop the $2500 for it.
Return to “Trinity GM Gas”
