Page 2 of 3
Posted: Tue May 08, 2012 11:38 pm
by Viciouslifter
It says i need a .cvs file, can you convert it?
I figured out how to convert it. But it says the AFR is not represented in the log file am i logging with a U7198, U7195, U7193, or U7192? Select Yes or No
Posted: Tue May 08, 2012 11:46 pm
by Mike_Levy
Select Yes. The Avalanche uses a U7193.
Posted: Wed May 09, 2012 12:03 am
by Viciouslifter
It's saying i need the "Command Throttle Position or the Absolute Throttle Position it's not represented in the file.
Posted: Wed May 09, 2012 11:44 am
by Mike_Levy
Which Dashboard are you using to log? Theres one just for DSLogRedux that has all the required info in it.
Posted: Wed May 09, 2012 4:45 pm
by Viciouslifter
Where do I find that logger at?
Posted: Wed May 09, 2012 6:25 pm
by Mike_Levy
Its on your Trinity. Instead of making yourt own, you should be able to open it up.
Posted: Wed May 09, 2012 7:31 pm
by Viciouslifter
Mike_Levy wrote:Its on your Trinity. Instead of making your own, you should be able to open it up.
Where is it located at?
Posted: Wed May 09, 2012 7:35 pm
by Mike_Levy
When you go to Logging, it should come up Choose a Gauge Layout. The top one says DS_LOG_REDUX. Select it.
Posted: Wed May 09, 2012 7:37 pm
by Viciouslifter
I don't have that option on mine all i have is GM_GAS, also how do i log the catalyst temperature.
Posted: Wed May 09, 2012 10:53 pm
by Viciouslifter
I made my own logger for redux I've done a little tuning and have noticed a huge difference so far! I'm loving this thing!
Posted: Thu May 10, 2012 3:15 am
by Viciouslifter
After two hours of logging and adjustments i've got my truck getting about 26-28 mpg highway and it has more power then i ever thought possible! My only addons for a stock 2005 Avalanche 5.3 Vortec V8 is the AFE Power Stage 2 cold air intake and a magnaflow 12579 muffler with stock cats/pipes. And of course the Diablosport Trinity tune, tuned by yours truly using diablotune as a base and adjusting with DSLogRedux! Thank You so much for your help! It's very appreciated
Posted: Thu May 10, 2012 9:49 am
awesome.
Posted: Thu May 10, 2012 3:08 pm
by 06MonteSS
Nce!!
Posted: Thu May 10, 2012 11:25 pm
by Viciouslifter
I've only been given two parameters to tweak, are there helpful tools for adjusting parameters other then slope and wot?
Posted: Thu May 10, 2012 11:50 pm
by Mike_Levy
Thats all you can do without the CMR software. CMR is for pro's only. Or wannabe pro's who can drop the $2500 for it.
