Page 2 of 5
Re: ABS light 5.7l HEMI Jeep Grand Cherokee
Posted: Fri May 10, 2013 11:33 am
yes, we are aware, and still working on the fix.
Its there, its just implementing it in the tool is not working out properly
Posted: Fri May 17, 2013 12:22 pm
by mschmid2
Hi Mike,
Any progress on this fix? Or is it still in queue to be worked on?
Martin
Posted: Fri May 17, 2013 2:12 pm
in the que for sure, I am trying to get another vehicle in here to sort it out for good.
Posted: Fri May 17, 2013 3:23 pm
by mschmid2
okay thanks. if y'all wanna trek it out to the denver colorado area you can use my vehicle.
Posted: Sat May 18, 2013 2:34 am
by Wolflead6
mschmid2 wrote:okay thanks. if y'all wanna trek it out to the denver colorado area you can use my vehicle.
Or Salt Lake City you can use my 2012 JGC 5.7L.
Posted: Mon May 20, 2013 12:12 pm
by mschmid2
hi mike! looks like comarsurewn needs to be removed from this forum...
Posted: Tue May 28, 2013 6:10 pm
by Wolflead6
mikel wrote:in the que for sure, I am trying to get another vehicle in here to sort it out for good.
Mike,
Prognosis for fix for ABS light issue on 2012 JGC 5.7L?
Posted: Wed Jun 05, 2013 12:25 pm
by mschmid2
hi mike,
any progress or still looking for test vehicle?
i will need to take my 2012 jgc to dealer for a free oil change soon... do you think i should just have them reset the light while keeping the tune i have in place?
martin
Posted: Wed Jun 05, 2013 3:25 pm
mschmid2 wrote:hi mike,
martin
Yes, they can reset it.
I plan to have a few 11-12 V6 Cherokee/Durangos in this week to sort this out while developing tunes
Posted: Wed Jun 05, 2013 6:13 pm
by Wolflead6
mikel wrote:mschmid2 wrote:hi mike,
martin
What about 11-12 V8's?
Posted: Wed Jun 05, 2013 6:18 pm
Wolflead6 wrote:mikel wrote:mschmid2 wrote:hi mike,
martin
Cherokee is a Cherokee, they'll have the same issue ideally, and the fix will be the same as well
Posted: Sat Jun 22, 2013 8:08 am
by AlexIV
[/quote]
as well for me. Mine is under factory warranty
I have to go to brand service dealer to check and replace the dashboard because of faulty buzzer.I cant hear park sensors or turn signals, whatever. I wonder what they would do. They definitely will see ABS light. And what they would discover in ECU ?[/quote]
So dealer has told me that there had been some (no record ? or wrong ? ) wrong writings in the tires size section. They'd fixed that issue. But now I afraid to write tune. Dealer told me that wrong records in that section could cause not only ABS problems but others as well.
So, Mike .....I wonder If I will not touch tyre size will I keep the ABS light off with 100% sure ?
Posted: Wed Jun 26, 2013 9:47 pm
by mschmid2
Took mine to Dealer to resolve ABS light. But it is not as easy as a 30 second reset of the ABS light. They reprogrammed the pinion factor to the closest tire size available to match the larger tires i have installed. Then reset the ABS light and it has so far stayed off. Apparently when they just reset the ABS light without reprogramming pinion factor, the light just comes back on quickly thereafter.
This was going to cost me roughly $150, but since they did it without having me approve the cost first I was able to negotiate to zero that out.
I guess i wont do any further programming now that the light is off and it appears i am finally good to go now. If I had known this would be an issue I would not have touched the tire size option. You guys should really put a notice on the product so people with these newer hemi's don't use the tire size option for those of us who have put on larger tires.
My two cents...
Peace out!
Posted: Mon Jul 01, 2013 11:25 am
by Wolflead6
[/quote]I plan to have a few 11-12 V6 Cherokee/Durangos in this week to sort this out while developing tunes
[/quote]
Mike, (tried to PM this instead of open forum but couldn't)
This is taking way too long, and of course waiting for a fix, the 30 day return period has ended.
Will we ever see a fix? When?
Bob
Posted: Mon Jul 01, 2013 3:11 pm
by nasmith342
I too am past my 30 day return period, and would like a refund on this tuner if the abs light, and other bugs are not fixed. I have a 2012 overland with a HEMI and not only is the ABS light on, but the tune doesnt work in sport mode, only in auto mode. This tuner should have never been released.... I am a C+ programmer and I would be fired if i released a shit program like this at my job...
