New 11-12 Wrangler features!
justo_y_franco
Re: New 11-12 Wrangler features!
Post by justo_y_franco »
justo_y_franco wrote:Hello,
I saw the new adjustable parameters, one of them for Fog Lights, but currently does not show any options under it. Are there not any options for it right now or else it should show and it is a problem I have with the latest upgrade?
I'm using the 87 octane tune and I'm getting between 1-2 mpg increase!
Regards
Can you answer the question about the Fog Light options currently available?
tadam
Post by tadam »
Regards
I would very much like the option under fog lights to allow them to stay on with high beams!
2012 Call of Duty
AFE CAI
In - Tune DCX Diablo Tune
currently its just enable fog lights with drl.
Flying2Fire
Post by Flying2Fire »
tadam wrote:Yes (all 42 psi), I forgot to include that info in my post.
I have seen this on a couple stock Jeep, 45 PSI is the high PSI warning thresshold, try lowering the tire pressure to 40 and see if that fixes the problem.
tadam
Post by tadam »
It is a low pressure warning.
2012 Call of Duty
AFE CAI
tadam
Post by tadam »
Mike,
Any ideas of how I can get rid of the low pressure tire warning/icon light that stays on?
tadam wrote:OK, still getting low tire pressure warning after I did the following:
-Restored vehicle back to original backup - low tire pressure warning light still on
-Re-wrote straight Diablo tune to vehicle - low tire pressure warning light still on
-Re-wrote with a couple quick adjusts - low tire pressure warning still on (I did this last one the way I wanted the final tune to be)
Please advise
2012 Call of Duty
AFE CAI
Tomiboy636
Post by Tomiboy636 »
Hi MikeL,
Is there a option for DRL settings? If not, can you include that option?
Cheers,
Not sure about that, will have to look into it.
We have an 11 JK in here that we're working with to get all these features working properly :)
tadam
Post by tadam »
3rd request please.
I cannot get rid of the low tire warning message even if I take it back to stock.
Please advise.
tadam wrote:Mike,
Please advise
2012 Call of Duty
AFE CAI
what if you set the threshold to 0 or 1 psi?
fpantaleano
Post by fpantaleano »
Is there a 93 Octane performance tune for the 2012 jeep wrangler V6?
fpantaleano wrote:Is there a 93 Octane performance tune for the 2012 jeep wrangler V6?
yes...
jwdemon
Post by jwdemon »
tadam,
Sounds like you have a broken tire pressure sensor. Had one on my Stang, the light never goes off, you need to replace it. I don't think they can turn the fog lights on with the high beams, it's against DOT rules.
Tomiboy636
mikel wrote:Not sure about that, will have to look into it.
Would be cool to be able to control--->
- DRL on-off
- Automatic always on when engine running (like in Europe)
- On with fogs
Cheers,
tadam
Post by tadam »
That worked, thanks for the help.
mikel wrote:what if you set the threshold to 0 or 1 psi?
2012 Call of Duty
AFE CAI
