Page 2 of 3
Re: New 11-12 Wrangler features!
Posted: Tue May 14, 2013 4:36 pm
by justo_y_franco
justo_y_franco wrote:Hello,
I saw the new adjustable parameters, one of them for Fog Lights, but currently does not show any options under it. Are there not any options for it right now or else it should show and it is a problem I have with the latest upgrade?
I'm using the 87 octane tune and I'm getting between 1-2 mpg increase!
Regards
Can you answer the question about the Fog Light options currently available?
Posted: Sun May 19, 2013 6:18 am
by tadam
justo_y_franco wrote:justo_y_franco wrote:Hello,
Regards
I would very much like the option under fog lights to allow them to stay on with high beams!
Posted: Mon May 20, 2013 11:09 am
currently its just enable fog lights with drl.
Posted: Mon May 20, 2013 11:35 am
by Flying2Fire
tadam wrote:Yes (all 42 psi), I forgot to include that info in my post.
I have seen this on a couple stock Jeep, 45 PSI is the high PSI warning thresshold, try lowering the tire pressure to 40 and see if that fixes the problem.
Posted: Wed May 22, 2013 3:34 pm
by tadam
It is a low pressure warning.
Posted: Sat Jun 01, 2013 7:42 am
by tadam
Mike,
Any ideas of how I can get rid of the low pressure tire warning/icon light that stays on?
tadam wrote:OK, still getting low tire pressure warning after I did the following:
-Restored vehicle back to original backup - low tire pressure warning light still on
-Re-wrote straight Diablo tune to vehicle - low tire pressure warning light still on
-Re-wrote with a couple quick adjusts - low tire pressure warning still on (I did this last one the way I wanted the final tune to be)
Please advise
Posted: Fri Jun 07, 2013 1:27 pm
by Tomiboy636
Hi MikeL,
Is there a option for DRL settings? If not, can you include that option?
Cheers,
Posted: Fri Jun 07, 2013 1:29 pm
Not sure about that, will have to look into it.
We have an 11 JK in here that we're working with to get all these features working properly
Posted: Mon Jun 10, 2013 2:14 pm
by tadam
3rd request please.
I cannot get rid of the low tire warning message even if I take it back to stock.
Please advise.
tadam wrote:Mike,
Please advise
Posted: Mon Jun 10, 2013 2:33 pm
what if you set the threshold to 0 or 1 psi?
Posted: Mon Jun 10, 2013 3:01 pm
by fpantaleano
Is there a 93 Octane performance tune for the 2012 jeep wrangler V6?
Posted: Mon Jun 10, 2013 3:33 pm
fpantaleano wrote:Is there a 93 Octane performance tune for the 2012 jeep wrangler V6?
yes...
Posted: Mon Jun 10, 2013 5:46 pm
by jwdemon
tadam,
Sounds like you have a broken tire pressure sensor. Had one on my Stang, the light never goes off, you need to replace it. I don't think they can turn the fog lights on with the high beams, it's against DOT rules.
Posted: Mon Jun 10, 2013 11:46 pm
by Tomiboy636
mikel wrote:Not sure about that, will have to look into it.
Would be cool to be able to control--->
- DRL on-off
- Automatic always on when engine running (like in Europe)
- On with fogs
Cheers,
Posted: Tue Jun 11, 2013 12:41 pm
by tadam
That worked, thanks for the help.
mikel wrote:what if you set the threshold to 0 or 1 psi?
