'13 MDS wont turn off
tacamo01
Re: '13 MDS wont turn off
Post by tacamo01 »
Everything seems to work fine except MDS. I have tried the 91 and 93 tune twice and the MDS is still active. I have HF Cats and Dynomax exhaust that needs resonators. You can definitely hear when the MDS kicks in. More sluggish and definitely in 4 cylinder mode. I even reset all parameters and then just tried to set MDS to off and it still stays on. But the tune itself is great until MDS kicks in.LOL
13 Charger R/T Daytona
tacamo01
Post by tacamo01 »
Here is a copy of the last 93 tune on the charger with MDS set to off. (But stays on)
PCM_68171355AC_Perf_93oct_modified.drg
93 tune mds off
(2.25 KiB) Downloaded 614 times
faisal
Post by faisal »
I have the same with my 12 SRT MDS wont go off
I am using 91 tune
tacamo01
Post by tacamo01 »
Well this AM I put the car back to stock. Original backup loaded just fine. Drove around and then disconnected the battery for 30 minutes. I checked the website for updates again and it only transferred two crom files. Images and loader. No others. I loaded the 91 Octane tune back on this time with parameters adjusted after the tune loaded. I adjusted the MDS to disable and throttle response to 18%. Attached file. The MDS stayed on while in Drive not autostick. You can definitely tell on my car. However, when I put it into autostick and started out in 1st through 4th at 40mph no MDS. I then got up to 45 -50mph and put it into 5th and no MDS. This did not work yesterday with the 93 tune as I tried autostick and normal drive and MDS came on with both. Now this may sound dumb, but I use autostick more than D for drive. So most of my driving will be on 8 cylinders and when I go on long trips I can benefit from the 4 cylinder mode. I do not think it is supposed to work like this but I like it. Anyway, any time there are new tunes for a car, no matter what the car, there is a learning curve. I learned this from my 11/12 Mustangs
PCM_68171355AC_Perf_91oct_modified.drg
(2.25 KiB) Downloaded 527 times
sharkcohen
Post by sharkcohen »
MDS will never come on when the car is in Autostick. If it really did when you had the tune installed, then something is really jacked up (highly unlikely).
garrett
Site Admin
Post by garrett »
Oh you mean the ECO identifier. That doesnt necessarily mean that it is in 4 cyl mode. It just means that you are driving efficiently. Even with MDS turned off the indicator will still come on. I can tell its going into 4 cyl mode by the sound and the slight jolt it gives when going in and out of MDS.
Were you able to take a look at the tune?[/quote]
I do not mean the eco indicator. If you have the Screen on your guage setup, you should be able to go through the menu options to see if MDS is engaged or not.
tacamo01
Post by tacamo01 »
garrett wrote:Oh you mean the ECO identifier. That doesnt necessarily mean that it is in 4 cyl mode. It just means that you are driving efficiently. Even with MDS turned off the indicator will still come on. I can tell its going into 4 cyl mode by the sound and the slight jolt it gives when going in and out of MDS.
I do not mean the eco indicator. If you have the Screen on your guage setup, you should be able to go through the menu options to see if MDS is engaged or not.[/quote]
MDS comes on in Drive. You can tell when it comes on in my car. I have JBA HF's and dynomax catback and the system is loud. Driving up to 45mph it stays off but then at cruise the MDS kicks in, you can feel and hear the difference when it goes into 4 cylinder mode. It is very noticable. Just the opposite when I use autostick.
garrett
Site Admin
Post by garrett »
tacamo01 wrote:Well this AM I put the car back to stock. Original backup loaded just fine. Drove around and then disconnected the battery for 30 minutes. I checked the website for updates again and it only transferred two crom files. Images and loader. No others. I loaded the 91 Octane tune back on this time with parameters adjusted after the tune loaded. I adjusted the MDS to disable and throttle response to 18%. Attached file. The MDS stayed on while in Drive not autostick. You can definitely tell on my car. However, when I put it into autostick and started out in 1st through 4th at 40mph no MDS. I then got up to 45 -50mph and put it into 5th and no MDS. This did not work yesterday with the 93 tune as I tried autostick and normal drive and MDS came on with both. Now this may sound dumb, but I use autostick more than D for drive. So most of my driving will be on 8 cylinders and when I go on long trips I can benefit from the 4 cylinder mode. I do not think it is supposed to work like this but I like it. Anyway, any time there are new tunes for a car, no matter what the car, there is a learning curve. I learned this from my 11/12 Mustangs
Tacamo01 , I just confirmed that the MDS is not shutting off, we will be working on getting this fixed for the next update
dtru1222
Post by dtru1222 »
Yes in the digital cluster there are two different identifiers, one says ECO and the other is Fuel Saver Mode. Both of which just tell you when your driving efficiently and will stay on even when MDS is turned off. They are not directly related to the MDS.
tacamo01
Post by tacamo01 »
Let's put this to rest, at least for my Charger! My MDS comes on in Drive and not autostick, which is normal from what I have been told.
I have owned enough muscle cars to tell the difference between 4 cylinder mode and 8 cylinder mode. It is not a subtle thing! It is something you hear and feel. I do not care if the ECO light is on or off!!
dtru1222
Post by dtru1222 »
tacamo01 wrote:Let's put this to rest, at least for my Charger! My MDS comes on in Drive and not autostick, which is normal from what I have been told.
lol thanks tacamo,
I understand that the MDS does not activate in autostick, I usually drive like this in order to avoid the MDS. The discussion is about the misconception that most people have, that the ECO/Fuel Saver Mode light does not mean that you are in MDS, it just means you are driving efficiently. Unless there is some other way, there is no identifier that will tell you that you are running in 4 cyl mode other than the exhaust note and the slight jarring when going in and out of MDS.
tacamo01
Post by tacamo01 »
Yep, and when MDS kicks in, with my exhaust it sounds like someone put 4 high energy vibrators to all four doors. LOL Only way to describe it!
tacamo01
Post by tacamo01 »
TKS, No rush, my loud exhaust has priority! LOL :D
GTFODodge
Post by GTFODodge »
garrett wrote:Tacamo01 , I just confirmed that the MDS is not shutting off, we will be working on getting this fixed for the next update
Do you have any sense of when the update will be released? Turning off MDS is a huge part of the reason I just bought a Trinity.
tacamo01 wrote:Here is a copy of the last 93 tune on the charger with MDS set to off. (But stays on)
The attachment PCM_68171355AC_Perf_93oct_modified.drg is no longer available
give this a shot
pcm_68171355ac_mds_off.drg
(69.23 KiB) Downloaded 736 times
