Ram 2012 Shift Points
Re: Ram 2012 Shift Points
Attached.jerseymike wrote:I have a 2013 Ram 1500 Express 6 speed. Can you please fix my tune so it shifts at 6200 rpms. Currently the 1-2 is set at 6000 and shifts at 6000 and the 2-4 is set at 6000 and shifts at 5700. I tried adjusting the HF tune to raise the shift points, also tried going back to the stock tune then reloading the HF tune. Please help. Also tried to manually shift but missed a shift and hit the rev limiter at 6200.I would like to shift at 6200. Thanks.
jerseymike
Thank you!!! Installed. I will test drive and report back.
jerseymike
I installed the tune and 1-2 is shifting at 6200 but 2-4 is shifting at 5900. It is better than 5700. Any ideas as to why it isn't shifting at 6200?? I reset parameters but did increase throttle response by 10%, shut off mds and pulled 3% fuel. It is much better just kinda weird??
I set them all at 6200....check the logs, could just be a slow tach.jerseymike wrote:I installed the tune and 1-2 is shifting at 6200 but 2-4 is shifting at 5900. It is better than 5700. Any ideas as to why it isn't shifting at 6200?? I reset parameters but did increase throttle response by 10%, shut off mds and pulled 3% fuel. It is much better just kinda weird??
jerseymike
I got a CEL for the trans last night. I was driving slow just cruising at 55. The trans was searching around for a gear. Then The check engine came on. So its says incorrect 4th gear ratio. Crap!! So I went back to the HF tune and cleared the code. Drove it real easy today and its ok so far. Not sure if it didnt like the new tune or my trans if really f*^ked. No wot runs till I can get it sorted out. I have to many mods to go to the dealer so Im thinking about a L & M trans or going back to stock and trading in on an 8 speed truck. You have any ideas???
8 speed has no tuning
It sounds like it may have slipped a bit if it threw that code, but thats odd.
Making a bunch of power?
jerseymike
I talked to Mike at L & M. After a long conversation I told him I had the battery disconnected a few weeks ago to install an amp. The trans has been shifting slow since then, like when it was new. He said to pick a tune and drive easy for 300 miles to give the trans time to relearn. So I put your tune back on and will drive easy for a few weeks to see if it gets better. No codes today but then again Im driving like a granny. I even had some old people on my ass. LOL. Lets hope this works. That is when it started shifting weird when I had the battery cable off. That is the first time since I got the truck that I disconnected the bat for this very reason, I didnt want the trans to have to relearn all over again.
Regular power. Headers, no cats, maggy 14", CAI, 2800 stall, 4.10 lsd, catch can, 180 stat, hf tune
No tuning for the 8 speed may be a good thing.
jerseymike
So my trans is shot. I went to two dealers today. I got lucky they are going to replace the trans under warranty. Im going to put the stock tune back on because they have to flash the PCM/TCM. What will I have to do later to get a my DS or HF tune back on there??
