Page 2 of 2
Re: Predator update
Posted: Mon Nov 11, 2013 12:02 pm
by mikdew1
can someone tell me why the diablotune get's more power and 3 mpg more than the mpg booster tune. Which either lost me a couple mpg or on it's best day kept my mpg the same as stock?
Re: Predator update
Posted: Mon Nov 11, 2013 12:11 pm
by garrett
what fuel do you use?
Re: Predator update
Posted: Mon Nov 11, 2013 9:27 pm
by mikdew1
Just 89 octane. No certain brand. Just wherever is the cheapest
Re: Predator update
Posted: Tue Nov 12, 2013 10:43 am
by garrett
the diablo tune is designed for 93 octane, you vehicle will be running worse than if you chose the 87 or mpg booster tunes.
Re: Predator update
Posted: Wed Nov 13, 2013 1:05 am
by mikdew1
But it's not. Running the lower octane i have more power and am getting almost 3 mpg more. That is with diablotune. If i switch to either of the other ones i loose the mpg i was gaining. power seems to be close but is lower. That's my question. How can this be?
Re: Predator update
Posted: Wed Nov 13, 2013 10:29 am
by garrett
there is absolutely no power gains from the MPG booster. i would suggest doing some logging on the tune that is meant for your vehicle, and verify the gas you put into the vehicle.
Re: Predator update
Posted: Wed Nov 13, 2013 2:28 pm
by mikdew1
as stated earlier I an not running mpg booster. not trying to b disrespectful but please reread my above posts
Re: Predator update
Posted: Wed Nov 13, 2013 3:14 pm
by garrett
[quote="mikdew1"mpg booster tune[/quote]
you specifaclly wrote mpg booster, and that the diablo tune gave you more power than that tune. the mpg booster is for 0 hp and 0 torque. strictly to using the active fuel management to give the best fuel economy.
Re: Predator update
Posted: Wed Nov 13, 2013 5:10 pm
by mikdew1
yes i did. but if you read the whole post you will se that i also sais it got me 3mpg better than the one that was supposed to save gas. that 1 actually cost me mpg. that is what i ca't understand. also that is with me running low octane with the one designed for high octane. maybe i'm just the kind of person that wants to learn and understand. i program plc industrial software for a living and it's just in my nature.
Re: Predator update
Posted: Wed Nov 13, 2013 5:13 pm
by mikdew1
can someone tell me why the diablotune get's more power and 3 mpg more than the mpg booster tune. Which either lost me a couple mpg or on it's best day kept my mpg the same as stock? But it's not. Running the lower octane i have more power and am getting almost 3 mpg more. That is with diablotune. If i switch to either of the other ones i loose the mpg i was gaining. power seems to be close but is lower. That's my question. How can this be?
Re: Predator update
Posted: Sun Nov 17, 2013 10:50 pm
by mikdew1
can no one answer?
Re: Predator update
Posted: Mon Nov 18, 2013 3:34 pm
mikdew1 wrote:can someone tell me why the diablotune get's more power and 3 mpg more than the mpg booster tune. Which either lost me a couple mpg or on it's best day kept my mpg the same as stock? But it's not. Running the lower octane i have more power and am getting almost 3 mpg more. That is with diablotune. If i switch to either of the other ones i loose the mpg i was gaining. power seems to be close but is lower. That's my question. How can this be?
I have no guess about the mileage, but the MPG booster tune is not designed to add power, so, thats why the diablo tune feels better
Re: Predator update
Posted: Tue Nov 19, 2013 5:21 pm
by mikdew1
Thanks for the answer. I am continuing to do logging and see if i can figure this out
Re: Predator update
Posted: Sat Nov 23, 2013 9:05 am
by justo_y_franco
mikel wrote:mikdew1 wrote:can someone tell me why the diablotune get's more power and 3 mpg more than the mpg booster tune. Which either lost me a couple mpg or on it's best day kept my mpg the same as stock? But it's not. Running the lower octane i have more power and am getting almost 3 mpg more. That is with diablotune. If i switch to either of the other ones i loose the mpg i was gaining. power seems to be close but is lower. That's my question. How can this be?
I think that having the extra HP and Torque with the Diablotune you won't need to push the gas pedal as much as having your vehicle with the stock tune.
