Page 2 of 3
Re: DTC P0605
Posted: Tue Nov 19, 2013 7:24 pm
by 808CVPI
sohfast94 wrote:Could post your last tune written form the intune/tunes folder and the info.xml?
What do you mean by "post"?
Re: DTC P0605
Posted: Wed Nov 20, 2013 10:05 am
by sohfast94
Attach it from the selection at the bottom where it says upload attachment
Re: DTC P0605
Posted: Fri Nov 22, 2013 7:09 am
by 808CVPI
I just did the speed limiter disble only...Check Engine came on again...here are the files...thanks!
Re: DTC P0605
Posted: Mon Nov 25, 2013 1:50 pm
by 808CVPI
Please don't forget me!
Re: DTC P0605
Posted: Mon Nov 25, 2013 1:56 pm
808CVPI wrote:Please don't forget me!
give this a shot
Re: DTC P0605
Posted: Mon Nov 25, 2013 2:00 pm
by 808CVPI
I'm new at this...how do I down load this and where do I put it? Thanks for the quick response.
Re: DTC P0605
Posted: Tue Nov 26, 2013 6:03 pm
by 808CVPI
Okay I took a guess and put it in the "TUNES" folder...we'll see if it fixes my problem...fingers crossed!
Re: DTC P0605
Posted: Tue Nov 26, 2013 6:42 pm
anywhere on the intune drive is fine, the tool should import it after a few seconds.
Re: DTC P0605
Posted: Tue Nov 26, 2013 7:22 pm
by 808CVPI
Okay, hooked it up...changed my speed limiter and so far "no check engine light"....I plan on changing my gears in the future soo I changed my axle ratio but no change in speed-o-meter reading...this actually the main reason for the purchase of the InTune...for a future gear change...
Re: DTC P0605
Posted: Sun Dec 01, 2013 8:46 pm
by sohfast94
Make sure you hit the enable switch in the menu for gear change.
Re: DTC P0605
Posted: Thu Dec 05, 2013 10:21 pm
by 808CVPI
Okay I'll check it out...thanks!
Re: DTC P0605
Posted: Mon Dec 23, 2013 7:42 am
by 808CVPI
Enable switch in the menu?
Re: DTC P0605
Posted: Mon Dec 23, 2013 7:52 am
by 808CVPI
Followed all the instructions on the screen....no change
Re: DTC P0605
Posted: Mon Dec 23, 2013 8:08 am
by 808CVPI
Changed it back and then changed the tire rotation....again no change...HELP!
Re: DTC P0605
Posted: Mon Dec 23, 2013 11:14 am
by sohfast94
Post your last tune written.
