Does intune in Neon SRT4 have WOT shift?
djkomplex
Re: Does intune in Neon SRT4 have WOT shift?
Post by djkomplex »
Awesome, thanks alot! I just got my walbro w/ bottleneck fix and a new fpr / fuel filter and replaced the sock, going to test my fuel pressure today and then hit my test spot to retune for the higher fuel.
I will post feedback along with logs so you can check it out.
djkomplex
Post by djkomplex »
Here is a datalog from the WOT shift. It definitely works! I tested it with the intune unmarried and when I tried to WOT shift the RPMs would rise, with the tune flashed, it seemed to hold the rpms while I shifted.
120513-WOT2.log
(39.18 KiB) Downloaded 177 times
k.archbald
Post by k.archbald »
I have a 04 Neon SRT4 as we'll.....can anyone tell me how well this tune worked and what mods people have who have run this tune?
djkomplex
Post by djkomplex »
The tune worked perfect! Kept the boost up and I believe it cuts spark maybe like the s1 does while in a WOT shift as it gives a nice flame out back... I would have to check the logs, I feel it works better than the stage1 implementation of it. I wouldn't do it to much unless you have the agp shift selector as if that little metal tab breaks off and falls in your tranny its no fun. As far as performance mods car is a 04 with the standard pcm, large front mount intercooler, k&n drop in filter, fuel pump rewire, agp wastegate with 8lb spring so I can use pcm controlled boost, 3" catless downpipe, booger bushings, agp shift selector, I did disconnect the solenoid for the factory surge valve and put in a cold side pipe with a hks ssq bov.
