Ok, so i bought the intune DCX and reprogrammed my car using Diablo Tune (around 1+ hour including updating the intune), first, noticed the car was less powerful, tried octane 91, again less power. went back to stock and felt the car was more powerful than Diablo tunes.
my question here is, i have a Magnaflow muffler, and K&N cold air intake, do i need to get a costume tune, or what am i doing wrong here ?
also, when i tried to adjust the tyre size, by entering the 3 parameters (width=285,height=50, rim=20), i got a message that says Failed, is this normal ?
waiting for your kind reply.
Dodge Durango 2014 / Jeep Grand Cherokee 2014 Support?
sultanalsooz
Re: Dodge Durango 2014 / Jeep Grand Cherokee 2014 Support?
Hoping for updates on the Trinity for the Durango 2014. Thanks!
you certainly should not be losing power, did you try the 87 tune?sultanalsooz wrote:Ok, so i bought the intune DCX and reprogrammed my car using Diablo Tune (around 1+ hour including updating the intune), first, noticed the car was less powerful, tried octane 91, again less power. went back to stock and felt the car was more powerful than Diablo tunes.
I would warn against changing tire size, it prob has little to no useful benefit anyway, who cares if speedo is off a bit, if ity means your ABS light NEVER GOES OUTsultanalsooz wrote:Ok, so i bought the intune DCX and reprogrammed my car using Diablo Tune (around 1+ hour including updating the intune), first, noticed the car was less powerful, tried octane 91, again less power. went back to stock and felt the car was more powerful than Diablo tunes.
sultanalsooz
The truth is, I'm not sure that anything was successfully changed, even eco mode settings seems to have no effect, the button light is always on.
Hope to see an update that actually works in the future, or maybe someone can explain what works and what doesnt.
Regards,
Regards,
Tell me about it -sultanalsooz wrote:The truth is, I'm not sure that anything was successfully changed, even eco mode settings seems to have no effect, the button light is always on.
Regards,
They give little to no info about breaks/fixes except baseless claims that things are fixed
With no hard data or notes or guidance on how when and where
I'm looking at an ABS LIGHT for 6+ months and randomly trying
To manually set it back to oem specs, tuning, detuning, updating croms, etc
To no avail - only help is "go to the dodge dealer" !? WTF?
Yet every day "1st to market blah blah blah "
I have same mods as you, KN and MF and with a hypertech interceptor vs this tuner I notice little
Difference...except with the interceptor I had more $$ in my pocket, and no yellow lights
Reminding me how not all product support and businesses are created equal
The ABS light issue was fixed a while back. Just make sure you have the latest update and then adjust the tire size again. After that the light will go off. worked for me.TRAUMA wrote:Tell me about it -sultanalsooz wrote:The truth is, I'm not sure that anything was successfully changed, even eco mode settings seems to have no effect, the button light is always on.
Regards,
sultanalsooz
Today I tested the stock tune with rev limiter increased to the max, my rev limits also had no effect.
Maybe my car is not the same as others, since it comes for gulf region (UAE), does it make a difference?
